Old 07-27-2005, 07:33 AM   #1
Sonia's Avatar
2006 34' Classic S/O
1992 25' Airstream 250
anywhere , New Jersey
Enkay Mud Flaps and Hensley Hitch
Hi,
We have a 2005 30' Classic with the Hensley Arrow hitch which we will be towing with our 2005 GMC Sierra 2500HD. We are thinking of getting the mudflaps from Enkay and want to know if this will work with the Hensley Arrow hitch.
When I called Enkay, they said that it can be done with some modifications. Before we invest the money in the mudflaps, we want to know if some of you have done this. If you have pictures, would you please post them too?
Sonia
Sonia is offline   Reply With Quote
Old 07-27-2005, 09:24 AM   #2
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Check out this link
Sonia,
I am also looking at the same setup. Check out this link:
http://www.airforums.com/forum...=enkay+hensley
I am really interested in your setup!! We have a 2005 2500 Burb and 27' Overlander with a Hensley Hitch.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 07-27-2005, 09:57 AM   #3
aluminauts's Avatar
vancouver , Washington
Talking Can be fixed by small "adjustment" to thickness
We "fit" the Enkay hub on our Hensley hitch by filing a portion of the hub where it was too thick to fit between the Tow Vehicle receiver and the drop tow bar of the hensley.
Others of the forum have machined the small refinement needed instead of the filing method.
I can add pictures later tonight.
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
aluminauts is offline   Reply With Quote
Old 07-27-2005, 06:55 PM   #4
aluminauts's Avatar
Here is the picture of our adjusted Enkay hub:
I think that milling would look cleaner than our "file job". Overall, I think less that 1/8 inch on about the top 1/2 of the rear face of the hub was effected. It still makes a faily snug fit between hub and receiver. Our upcoming Unit rally will be our first use of it. We'll see how it functions.
Cutting the rubber was tougher than I thought and I also had to get a hole cutting drill to cut the hanging holes, the "punch" Enkay provide did NO CUTTING of the rubber flap at all.
Like always the job was more than I thought, but might work out ok after all.
Aluminauts
Allison Duramax 4X4
Hensley Arrow hitch
Doran Pressure Pro
Old 07-27-2005, 08:42 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Sonia,
I had a local machine shop mill mine out for the 6" drop on my Hensley and Enkay combination. I will take some pictures tomorrow and post them. I am more than satisfied with how they work together.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-28-2005, 01:04 PM   #6
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
News Flash
FWI,
If you have a Hensley Hitch and are thinking about getting the Enkay Rock Tamers. I just got this note from Enkay:
"Thank you for you inquiry regarding the Rock Tamers. Our full-size Rock Tamers will fit your vehicle perfectly. As for the Hensley Hitch, we recommend you contact Sean at Hensley Hitch directly and he will take care of your hitch for you. We recently began a relationship with Hensley and they are adapting their hitches to accommodate our mudflap system. You may reach Sean from Hensley Hitch at 800-410-6580 ext. 100. Good luck with your new system."
I spoke with Sean and he will exchange your drop bar with a "special" Hensley bar that is one inch longer so you will not have to "modify" your Enkay. The exchange is free (you pay for shipping) The only down size is the "special" bar is not available for the free lifetime exchange program.
Hope this helps any one interested the Hensley/Enkay combo!!
Hensley Hitch
Old 07-28-2005, 02:20 PM   #7
Which leads me to beg the question... what does it mean to give up the lifetime exchange and am I better off doing the filing modification? Would appreciate feedback and photos from others. Tom, and Frank
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Old 07-28-2005, 05:47 PM   #8
davidz71's Avatar
1986 25' Sovereign
IF you never plan on getting a tow vehicle taller or lower than what you have now then you could afford to give up the exchange program. That is a big IF! It would seem to me that it would be cheaper in the long run to have the center milled out at a cost of $20-30 or so and be able to use it on any length Hensley stinger in the future.
Craig
AIR #0078
3.73 rear end
Old 07-28-2005, 06:15 PM   #9
I don't like that IFFFF one bit and it can't be cheap to buy another Hensley shank.
Tom and Frank
Evanston, Illinois
Old 07-29-2005, 05:36 PM   #10
davidz71's Avatar
1986 25' Sovereign
Enkay Rock Tamer Modification
Sonia,
My pictures run 142-145 KB each and the limit is 100 with the program I am using. I will wait for my computer whiz son to get home so that he can reduce the size and I can post 8 pictures I took this afternoon.
Craig
AIR #0078
3.73 rear end
Old 07-29-2005, 05:46 PM   #11
davidz71's Avatar
1986 25' Sovereign
PWRSTRK,
The Enkay hub had to be modified slightly deeper than the one shown on the Sunnybrooktalk forum but I can only guess it was due to the difference in truck receiver dimensions. I took the center hub, stinger and truck to a machine shop and one of the guys took measurements. I think they had to take as much as .460" off one of the areas to clear the stinger. The final result is a tight fit just allowing the pin to hold the stinger in place without fighting to get it all the way through the holes. I don't see any structural problems since there is plenty of metal.
Craig
AIR #0078
3.73 rear end
Old 07-31-2005, 06:23 PM   #12
davidz71's Avatar
1986 25' Sovereign
Picture of center hub.
Craig
AIR #0078
3.73 rear end
Old 07-31-2005, 06:36 PM   #13
davidz71's Avatar
1986 25' Sovereign
Another center hub shot.
Craig
AIR #0078
3.73 rear end
Old 07-31-2005, 06:43 PM   #14
davidz71's Avatar
1986 25' Sovereign
Others pictures:
ID:	13702   Click image for larger version
Craig
AIR #0078
3.73 rear end
Hensley and Rock Tamer davidz71 Hitches, Couplers & Balls 12 03-31-2005 08:55 PM
