Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 05-12-2008, 07:16 AM   #1
Jared129's Avatar
Profile:  1976 31' Sovereign
Durham , Maine
Dent removal...
While I am still a ways away from thinking about dealing with it, for future reference how big a can of worms will I be in when it comes time to fix this dent? Is it going to require complete segment replacement? I almost have the "it isnt broken dont fix it" mentality because it is more cosmetic than anything else (no leaks or anything thankfully).Click image for larger version
Jared and Heather
Jared129 is offline   Reply With Quote
Old 05-12-2008, 07:39 AM   #2
Melody Ranch's Avatar
Profile:  1966 17' Caravel
Valley View , Texas
Images: 18
dent removal
Sorry to say....you are about 1000 dollars away from a good removal.....probably plus a fuel surcharge of some sort. If you can live with ripples and smaller dents....push it out as best you can from the inside.
Old 05-12-2008, 08:03 AM   #3
DanB's Avatar
Profile:  1970 23' Safari
Lorain , Ohio
I had the same dent on the front of my Safari, I've still got a matching one on the back!
The front was "easy" to fix. I went nuts for two hours with a cordless drill. Rivet carnage was everywhere. Lots of interior panels were removed.
I then palmed and pushed it up into place. It's not perfect, but I'm pleased with the results. It took about eight hours to refit the panels and clean up. This was using a phematic rivet gun.
Now the back one! That's a different story! I'll have to pull the bathroom to do that one. Looks like a couple of week job.
Good luck!
DanB
________________________________
Always Looking for Pinball Machines!
DanB is offline   Reply With Quote
Old 05-12-2008, 08:18 AM   #4
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
Dents
Hi
I am in the same boat you are, and I'm going to try this technique this summer.
Somewhere on this site the owner of a similar dent used a hot glue gun and glued a bunch of 3/4 to 1" dowels all over the dented area as handles and slowly pulled from the outside of the dent and worked his way in to center. Similar to stud welding technique. Be sure to do it on a hot day or heat the area. He was able to remove a substantial amout of damage. He then used mineral spirits to remove glue residue. I have not tried this but it looks like a workable alternative to removing the bath area to get to the backside of dent.
good luck.
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 05-12-2008, 09:58 PM   #5
Jared129's Avatar
Durham , Maine
Wow, those are definitley some nifty ideas worth trying...maybe I will get adventurous ssoner than later with it... Thanks everyone...
Jared and Heather
Old 05-13-2008, 07:13 AM   #6
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Ding KIng
Originally Posted by The Flintstones
Hi
good luck.
James
The above technique will significantly reduce the dent but it won't get rid of any creases. There are 2 commercial versions of this technique Ding King and Pops a Dent. Some people also use auto body suction cups.
Hops make the hippy happy
Old 05-13-2008, 07:29 AM   #7
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Here is a link to the sticky sticks approach. Thanks to Doorgunner for the name sticky sticks. I haven't completed the last big dent and play to post more detailed info when that is done.
dent repair on rear corner
The last one is giving me more trouble because someone tried to straighten it with the suction cup method, did not know what they were doing, and made it worse.
Royce (K0RKK) and Karen
AIR# 3913
Royce is offline   Reply With Quote
Pingbacks are On
Dent removal gergstuff All Argosy Trailers 10 06-14-2007 09:16 AM
Dent Removal Steve Heywood Ribs, Skins & Rivets 21 06-18-2005 07:51 PM
Dent Removal/Hurricane damage ASFlorida25 Ribs, Skins & Rivets 11 11-18-2004 06:19 AM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 09:15 AM
dent removal nevisstudio Ribs, Skins & Rivets 8 01-14-2004 12:45 PM
SEO by vBSEO 3.1.0
