08-13-2015, 09:01 AM
2014 27' FB International
Macon
, Georgia
Cracked Plexi Rock Guard
I have an crack on my curb side plexiglass curved rock guard. The L shaped crack is about 1 inch horizontal and 4 inch vertical crack. Should I replace the rock guard now or wait until I have more cracks? I wonder if another rock hits the cracked area, whether it will go through.
08-13-2015, 09:25 AM
2000 25' Safari
1999 34' Excella
Davidson County, NC
, Highlands County, FL
I have a few cracks in mine, from three different rocks on the Excella and one on the Safari. I have no plans to replace them.
Alan
08-13-2015, 09:32 AM
Oswego
I have several, when it gets bad enough, I'll replace with polycarbonate.
-Rich-
08-13-2015, 09:39 AM
2007 27' Classic FB
Fredericksburg
One thing you might try to delay replacing the rock guard is to obtain some liquid acrylic (or acrylic cement) and slowly squeeze it into the lines of the crack. It will seal the crack and minimize problems if you are hit with another rock.
The Tex-i-can is Ready to Camp
08-13-2015, 09:40 AM
In the mean time……..
You could put a cool sticker over the crack. It might slow down the spread of the crack if you drilled small holes at the ends of the crack.
08-13-2015, 10:40 AM
Is it just me that has aluminum rock guards on my old Excella...? when did Airstream move to a pexiglass (?) rock guard... was that a cost-saving move for them?
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
08-13-2015, 10:51 AM
Oswego
We're talking about the window guards, not the corner protectors.
-Rich-
08-13-2015, 11:54 AM
2015 25' Flying Cloud
GILBERT
We just return from a 6000 mile trip to the Northwest and thank GOD I got a
ROCK TAMER MUD Flaps on my TV and did not see one ding on the AS or crack window guard. Well with the $200+
I camp next to another AS in Montana and he had all 3 windows guards broken from rocks on the road over the last 2 years.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
08-13-2015, 12:08 PM
Oswego
Yeah I have rocktamers. They don't help with stones thrown form passing or oncoming vehicles.
-Rich-
08-13-2015, 12:30 PM
2014 25' FB Eddie Bauer
Vero Beach
I took a rock to one of my plexi wraps on i90 in SD in July. Went right through leaving a hole the size of a dollar bill. It saved the glass underneath. That part new from airstream will set you back almost $500. You can install it in 10 min with minimal effort. The window underneath is almost $1,000 and must be rerivited.
I'd live with cracks for $500 but replaced mine given the hole and a personal belief that sometimes lightning does strike twice.
08-13-2015, 01:33 PM
Oswego
Gamma, I assume you replaced frame and all? You can, with some cutting and riveting get plexi (or polycarbonate) stock and replace the plastic only. I understand, however, that plexi has to be heated to make the curve of the side guards....could be tricky.
-Rich-
08-13-2015, 01:50 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
To have the best strength Plexi window guards need to be formed by what is called slump molding. You have a wood male form mold and then heat the plexi up to the point that it droops over the form to make the curve. This results in no molded in stress and the window guard is best at resisting stones. If you cold bend plexi you have a high stress and it will crack if impacted with a small stone. Poly carbonate (Lexan) is somewhat subject to the similar limitations. It must be heated slowly to dry it out and not cause bubbles to form.
08-13-2015, 01:55 PM
Oswego
Dwight, I keep getting mixed info on the poly. Some say that with thicker sheets, heating is necessary but not thinner sheets. I don't remember thicknesses mentioned, nor what is OE in our plexi guards. Thinner and more crack resistant may be better than thicker plexi????? If it is thinner, I'd just have to find extra thick spline material (they already use special order thick spline with the OE setup.
Can you shed light on the thickness debate?
-Rich-
08-13-2015, 10:07 PM
2013 25' FB Flying Cloud
Colorado Springs
Subscribing, this is interesting....
