Old 09-12-2015, 08:19 AM   #29
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by tjdonahoe View Post
I built my mud flaps, used angle iron bolted above and in front of the rear bumper ,they stick out 2" past the tires on the outside ,are low to the ground, I like them better than the rock tamers , which are hanging on the wall.
Originally Posted by Siegmann View Post
Out of curiosity, what material/source did you use for the "flaps"?
Hi, I did the same thing for my Lincoln; Mud flaps attached to angle iron and mounted under my bumper and to my receiver. I bought universal mud flaps from a NAPA truck parts store. I got a nice rock chip in my windshield and my rock guard from passing trucks.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-12-2015, 09:37 PM   #30
1998 30' Excella 1000
Livingston , Texas
Robert, thanks--
Siegmann is offline   Reply With Quote
Old 10-16-2015, 03:11 PM   #31
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Photo of cracks in rock guards
This does not add a lot to the discussion, but here is a pic of my door side rock guard which has numerous cracks. They are not noticeable when the rock guards are locked in place. None of the cracks go all the way through and all started on the inside. The other one has some, but not as many. I'm going to keep an eye on them to see if they spread. For all I know they were there when I bought the AS a couple of years ago. I opened them to clean them since the windows were so dirty.
Name:	cracks in door side rock guard.jpg
ghatfield is offline   Reply With Quote
Old 10-16-2015, 06:20 PM   #32
Livingston , Texas
Ghatfield, I vaguely remember reading that the rock guard plastic is not compatible with either the ammonia or alcohol in certain window cleaning solutions, and that they could cause cracking. Don't know if that is the case with your rock guards.....
Old 10-16-2015, 11:23 PM   #33
ghatfield's Avatar
2006 19' Safari SE
There is another interesting thread on this topic...
http://www.airforums.com/forums/f469...ds-102064.html
These "cracks" might be due to crazing of the plastic. Might give the superglue a try to arrest the cracks. I have never used ammonia nor alcohol on the rock guards, but I bought the Bambi used so who knows what happened previously. Like I said the cracks are not very visible from the outside. It is only when I pulled them away from the window and looked out from the inside of the rock guard did I see them.
Old 10-17-2015, 04:44 AM   #34
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Window rock guard cracks
I have accumulated several dents in the SS guards, a couple star shaped cracks in the window guards.
So, just installed new Rock Tamers, hopefully this will decrease the problems.
I believe I will try the cyanoacrylate super glue to see if it fills the crack. My largest hit so far was apparently a tire tread which bent the SS shield back to the aluminum.
Oh, well.....
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-17-2015, 04:53 AM   #35
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I had a rock crack one of mime on our first trip.
I stop drilled the end of each line of the crack and then used a syringe to apply acetone to each of the cracks. The cracks have been stable for a year and a half.
Acetone very effectively welds the plastic.
2012 Dodge Durango Hemi/AWD
Old 08-27-2016, 08:57 PM   #36
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Washing my 2008 Classic 25fb. Swiveled the street side front corner window rock guard out to clean and noticed in the upper corner adjacent to the center window two stress cracks from the corner. The longer one is a couple of inches long. Starting to occur on the curb curved window rock guard too, a crack coming from the corner but less than an inch. Found replacement part online; $500 for each corner.
I notice when I unlatch the clips on the windows they seem to have tension. When secured you have to lift the window to line up the clips so the rock guard seems to be under some stress before the trailer hits the road.
Its hardly noticeable from the outside due to the dark tint. Will it get worse? I can live with it if the crack doesn't get any longer.
Kelvin
Old 08-27-2016, 10:58 PM   #37
ghatfield's Avatar
2006 19' Safari SE
We have a 2006 Bambi and our front side window rock guards developed severe cracks. Some were several inches long and went all the way through the plastic. I finally replaced the curb side since it had the most cracks and I questioned how much protection it would provide. The cost was about $600 which included shipping to Tucson. Installation was easy although I had to remount one of the locking mechanisms on the trailer.
Old 08-28-2016, 04:02 AM   #38
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The "Plexiglass" material, that the guards are made from, is susceptible to chemical stress crazing. The crack pattern will tell you whether this has occurred or the cracks were caused by an impact. Do not clean the guards with cleaning products that contain alcohol. here is the link to the list of chemicals that can cause acrylic to fail. http://www.eplastics.com/Plastic/pla...iglass-Acrylic
Old 08-28-2016, 06:42 AM   #39
KJRitchie's Avatar
2008 25' Classic
I'm wondering if my rock guards where mounted incorrectly. When the rock guards are swung around to be secured the Dzus fasteners don't line up with the rubber grommeted holes. I have to lift the guard frame up and secure the bottom fastener before the top fastener. Is this putting strain in the frame and plexiglass? Add towing vibration and I can understand the failure.
I guess you can't get the plexiglass replaced, have to buy the complete guard.
Kelvin
Old 08-28-2016, 08:04 AM   #40
Wayne&Sam's Avatar
Images: 21
Stop drill the leading edges of the crack then weld it with acetone. I used a syringe and needle to apply the acetone.
Old 08-28-2016, 08:23 AM   #41
KJRitchie's Avatar
2008 25' Classic
I'm taking my Airstream to A&P in a couple of weeks. I'll ask Paul about the rock guard.
Kelvin
Cracked Plexi Front Windshield interstateflyer Rock Guards, Segment & Window Protectors 23 06-04-2015 12:52 PM
Cracked window rock guard Edistobob Windows & Screens 5 08-06-2014 08:08 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Cracked Window Guard Pat Cassity General Repair Forum 2 06-03-2014 01:47 PM
Cracked side rock guard Argy 78 Rock Guards, Segment & Window Protectors 6 03-22-2012 08:59 PM
