Old 05-21-2015, 02:48 PM   #15
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Ultra Guard is what I have on my truck.
Old 05-21-2015, 04:12 PM   #16
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
As a retired plastic fabricator I can tell you this. Polycarbonate i.e. Lexan, can be bent cold if the thickness is 1/8" or preferably even less. .080-.100 I will not relax into the curve but has to be held under tension. This will eventually result in hairline stress cracks. It absorbs water from the air and as mentioned above it must be slowly heated to drive the moisture out before heating it up to 350 where it can be moulded over a jig. This is complicated voodoo and we refused to even attempt such jobs at our shop. It also explains why Harley D windshields are so expensive. It is a lot easier to hot mould acrylic so that is what the stone guads are made of.
Gearheart is offline   Reply With Quote
Old 05-21-2015, 04:23 PM   #17
dznf0g's Avatar
Oswego , Illinois
Can Plexi be installed cold in our AS wrap around window guards?
-Rich-
Old 05-22-2015, 08:35 AM   #18
2002 25' Classic
Kalama , Washington
Consider stopdrilling to resist further cracking. Common strategy used in non pressurized aircraft window repair. A small hole is drilled at the leading end of a crack (which distributes stress across a larger area). A clear filler can then be used to seal it.
Method works equally well for metal cracks.
nwclassic is offline   Reply With Quote
Old 05-22-2015, 08:32 PM   #19
'78 Sovereign
1978 31' Sovereign
Santa Rosa Beach , Florida
Here is a good laugh that will also answer the question about lexan's flexibility. I have a good deal of experience with plexiglass in helicopters. The fix we used in crack repairs was to "stop drill" the extreme ends of all cracks, thus stopping their radiation(growing). On longer cracks after stop drilling we used 18 gage(phone line size) copper wire to lace the crack much like shoe laces after Drilling equidistant holes along both sides of the crack and the ends. Not pretty but functional and met flight safety to exceed 100 knots airspeed. Maybe I'll do mine and post picks.
Another important thing to know about plexiglass or lexan's is to not use any cleaners that have ammonia. It will degrade the polymers and cause chemical induced crazing and eventual failure.
frankrightbrain is offline   Reply With Quote
Old 05-25-2015, 08:07 AM   #20
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Go with Lexan for your rock guards it is more suitable. Above Gearheart states which thickness to safely use. Lexan cold forms to the compound curve just fine. I replaced a busted wing window where the PO had previously put in plexi. The plexi was in awful condition with full length breaks as well as being super yellowed and hazy, it obviously did not weather well.
thesignlady is offline   Reply With Quote
Old 05-27-2015, 06:21 AM   #21
dznf0g's Avatar
Oswego , Illinois
OK, so we're back to my original statement in post#4? The polycarbonate, in thinner sheets can be used in the wraparound, newer rock guards, without heating and make the curve in a cold bend.
Incidentally, I don't think any drilling is required in the newer ones. I believe they just slip in the frame with an end removed and are held, floating, with window screen spline.
-Rich-
Old 05-27-2015, 07:27 AM   #22
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I replaced the cracked plexiglass on my Rockguard with ABS. The ABS sheet has a smooth side and a textured side, I installed smooth side out. Much higher impact resistant but you cannot see thru it.
Very flexible and easy to work with.
Just my take on this issue.
Mike
desertair27 is offline   Reply With Quote
Old 05-27-2015, 07:56 AM   #23
dznf0g's Avatar
Oswego , Illinois
I need to see through it on a 3 piece. The corners do not open like the center one...unless you remove them totally....and that's not a viable option.
-Rich-
Old 06-04-2015, 12:52 PM   #24
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
as far as the crack, you may be able to use some Mek and a syringe. when people build things out of acrylic, you hold 2 mating parts and then squirt the liquid in there and capilary action draws it in, then bonds it, and clear. Weldon makes most of the products. I believe I got some from Southern States.
Rob
robwok is offline   Reply With Quote
2003 Airstream Cracked Windshield RVtomtom Land Yacht/Legacy Motorhomes 4 06-04-2012 06:43 AM
Plexi or Glass? rasmuw 1959-69 Tradewind 4 08-17-2007 06:02 PM
Keep the plexi inner window or not? Vinoblanco Windows & Screens 1 03-25-2006 09:14 PM
