Old 06-08-2005, 06:20 PM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Classic Rock Guard problem
Attached are two images showing the rub caused by the rock guards. We notices this while washing the trailer.
We also found that nearly every screw on the hinge was loose. The stree side was more loose than the curb side. The two nuts holding the outside of the guards were tight on both sides.
As anyone else experienced this? Any suggestions on how to repair and prevent future problems?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 06-08-2005, 06:31 PM   #2
Gus.
The causes are lack of proper running gear balance, excessive rated hitch, and/or a tow vehicle with overload springs.
Any one of these things can cause the problem.
The chafing is cause by vibration.
Inland RV Center, Inc.
Old 06-08-2005, 06:35 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Gus....ours are fairly close too, but we have never seen that on ours.....ever consider trading this unit?
Old 06-08-2005, 06:42 PM   #4
gklott's Avatar
2004 30' Classic
Images: 53
Causes
- proper running gear balance - new tires on trailer, new tires on truck, all balanced within past 3 months, trailer aligned in December, not far off
- excessive rated hitch - not really sure what this means, we have the standard class c hitch on the GMC Sierra 2500 HD
- tow vehicle with overload springs - see weights on other post
Why would this only happen here? What other signs would there be from the above 3 items?
73/gus
2004 30ft. Classic
Hensley/Prodigy
Old 06-08-2005, 06:45 PM   #5
gklott's Avatar
2004 30' Classic
Images: 53
Trading to what? We've seriously considered leaving RV ownership because of our problems.
73/gus
2004 30ft. Classic
Hensley/Prodigy
Old 06-08-2005, 06:55 PM   #6
73/Gus
Your tow vehicle is heavy duty. If you, as an example, have a 1000 to 1200 pound rated torsion bars on your hitch, then that's the problem.
The front of the trailer "must" freely move up and down. If you have a large weight rated hitch, then you have restricted that movement.
Therefore any road shock will be transfered to the trailer front end, beat it and anything else on the front to death.
If this is the case, drop the hitch bar rating to 550-600 pounds, no more. That will give the trailer a softer ride and stop any further damage.
Old 06-08-2005, 07:16 PM   #7
Aluminut
2004 25' Safari
. , Illinois
Gus, I sent you a PM.
...and Andy, I think I asked this before, since I got the Suburban, the Impala had 1200lb bars which worked well with that soft suspension, but the Suburban is a 3/4 ton and I downgraded the weight bars to 800# bars. The hitch weight on the Safari is suppose to be about 750lbs.....do you think I'm overhitched? Think I need to go to the 600lb bars? I've driven about 1000 miles with the ol Burb and the Safari and so far haven't seen my rock guards, though close to the body, do what has happened to Gus'. Yet, there have been times when I can feel when the trucks come by me....I'm puzzled any ideas?
Old 06-08-2005, 07:53 PM   #8
gklott's Avatar
2004 30' Classic
Images: 53
We've already driven over 35,000 miles with the trailer since July 2003. Is that the BIG difference - road miles? Much of ours is interstate driving at 70 MPH.
73/gus
2004 30ft. Classic
Hensley/Prodigy
Old 06-08-2005, 08:00 PM   #9
Aluminut
2004 25' Safari
. , Illinois
I don't know if it's a mileage thing myself...I was just wondering if it would eventually happen to mine if I kept the 800lb bars on with our Suburban.
Old 06-08-2005, 09:01 PM   #10
wrepete's Avatar
1996 28' Excella
Geneseo , New York
Gus
I had the same problem with mine, and was fortunate enough to be at the AS factory when I noticed the guards were working loose. They advised me that their solution was to add another support at that location, so I purchased the support at their store and added it myself. I tightened up all the fastenings, including replacement of some rivets that had worked loose. . . end of problem. That was five years ago. If my problem was based on flexing of the whole front end, I believe this solution I used would not have worked.
Hope your solution is as simple.
Bud
Bud
1996 28ft Classic
2008 Silverado Duramax 2500HD
Hensley/BrakeSmart/EnKay
wrepete is offline   Reply With Quote
Old 06-08-2005, 09:44 PM   #11
gklott's Avatar
2004 30' Classic
Images: 53
Wow. Sounds like what I need. Can you post a picture? Do you have a part number?
73/gus
2004 30ft. Classic
Hensley/Prodigy
Old 06-08-2005, 11:36 PM   #12
1992 34' Limited
Falls Church , Virginia
Additional support location???
Bud -
Also, have a similar question to the post before me. Where did you add the additonal support as SilverToy has similar rub marks. Had it when I got her, so I have no clue as to why they are there. Just to try to be clear as mud - did you add the support 1/2 way round the guard in the middle of the arc it makes at the trailer front? Top and bottom? Which support did you use - the SouthCo rubber thingy with the 90 degree turn screw fitting? Details at least, photos prefered!
BTW - thanks for this timely post as I have a BIG trip planned in a few weeks and don't want this to get worse! That leads me to another question....
Question for Andy. Asked this before but got no response. Am I 'over hitched' in your opinion? Have the 34' Classic, '01 2500 'Burb, and Equal-I-zer 12K with 1K bars. Is this over kill and should I get 800lb or 500lb bars but keep the hitch head?
As mentioned, big trip coming up and want this resolved ( if that is in fact what I need to do) before I leave, and possibly making my rub situation worse.
Thanks in advance for your answers/opinions.
Axel
SilverToy is offline   Reply With Quote
Old 06-09-2005, 02:40 AM   #13
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
73/gus
Gus -
You don't think that having nearly every screw loose on the hinges might have caused this? And, following Andy's list of potential causes, did one of those things create the vibration to loosen the hinge screws.
I got into a habit of checking my rock guards frequently after my dealer told me to do this because he said that sometimes the screws holding them in place come loose and people look back to see their rock guards flapping in the breeze (not a pretty sight ).
I also open mine regularly to clean behind them.
- That just reminds me that I should ask when I'm in Jackson Center a couple weeks from now why they only secured my rock guards with half the number of screws that there are holes for on the hinges.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-09-2005, 06:32 AM   #14
gklott's Avatar
2004 30' Classic
Images: 53
Don't know what the cause is. Our Classic has spent 4 months in the shop for warranty repairs during the first 23 months. I'd have thought they would have noticed any problems so obvious.
Haven't had any noticible vibration effects inside the front of the trailer - such as pillows moving on the couch or items moving in the drawers.
Perhaps the rubs resulted from vibrations caused by our tires before they failed.
Plus, we've put a lot of miles on the trailer - which may have caused this to show up so soon.
Will try to get the Airstream part to add one support.
73/gus
2004 30ft. Classic
Hensley/Prodigy
Online source for classic cars & more 83Excella Off Topic Forum 4 03-05-2007 09:02 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
