Old 07-14-2010, 11:48 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Broken Window now I know why I need a Rockguard
So the dusty road in Nebraska scored a direct hit on my street side front curved window on my 72 TW. So now I know why they make a rock guard.
Anybody know where to get a front window?
RichHog is offline   Reply With Quote
Old 07-15-2010, 01:15 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Andy has 'em at Inland RV. Not a trivial job to replace, but doable. You'll need window, Vulkem & Olympic rivets.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-15-2010, 04:21 AM   #3
x
XXXX , XXXX
Richhog check the classifieds a mjmarkhams70 from Katy Texas has some listed for sale.
wasagachris is offline   Reply With Quote
Old 07-16-2010, 09:07 PM   #4
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Window broken
Do you replace the frame that has both the inner and outer windows, or just the glass on the outer frame?
Old 07-16-2010, 10:04 PM   #5
The wing windows only come complete with the metal sash (frame) around the glass.
The rivets must be drilled out to replace wing windows.
Not a biggie to do. Instructions are pretty easy.
Old 08-12-2010, 11:02 AM   #6
1972 27' Overlander
Saline , Michigan
Rich,
I had the same thing happen a few weeks ago, what have you done? Is your inner pane ok, mine is and I am considering just taking out the broken outter pane and then caulking the void with vulcum.
Let me know what you have done and if it worked for you. someone else must have dealt with this, anyone running with just the inner pane? A new window will just have one pane.
loechli is offline   Reply With Quote
Old 08-13-2010, 08:35 AM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Haven't done anything yet as the inner pane is still there. Probably should at least remove the rest of the broken glass. Andy says they have the single pane replacements so plan to buy one and put in later. I don't know if leaving just the inner pane in place is a good idea, need to check if there would be any leaking around the seals. Figured I'd pay off the credit cards from the trip first and then order the new pane and a rockguard.
broken window cole graham Windows & Screens 2 04-06-2009 09:01 AM
Front window rockguard panel splines. IrishRover2 Windows & Screens 1 02-20-2007 09:47 AM
Broken window cjholloway Windows & Screens 4 03-31-2004 06:26 AM
Front Window Rockguard themartaman Windows & Screens 3 07-14-2002 11:01 AM
