Old 02-15-2006, 08:59 PM   #1
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
broken rock guard
has anyone replaced the plastic on the rock guard frame?--If so where would I find it? I like the look of the black plastic that I see on everyones AS,but does it let enough light into the trailer when closed? thanx tubers--jim from mich------am posting the very first modification to my safari-a copper trim insert around the counter--what do you think?--I dig it!--the countertop is nest---jim
Name:	trailer furn. 003.jpg
jamesardis is offline   Reply With Quote
Old 02-15-2006, 09:13 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
The rock guards are just Acrylic Sheet. You can purchase it from plastic distributors and most glass shops. You can get it in various tint densities to meet your needs. You will have to drill out the corner rivets in order to disassemble the frame, but it is easily done.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 02-15-2006, 10:19 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Rock Guards
JIM, You can also just replace that rock guard with a new one. They are available from Airstream dealers. The Lexan they are made of is scratch resistant. So if you just rebuild your old one when you go to the glass shop remeber to say the Lexan scratch resistant is the type you want. Don't let them sell you the cheaper regular Lexan or Plexiglass as they will show every scratch for every time you wash them or everything that touches them. Ed
BIGED52 is offline   Reply With Quote
Old 02-16-2006, 11:10 AM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Gary, I believe you are thinking of the rectangular rockguards. The rock guard for a '71 would be curved and contoured. The original frames were very flimsy and the thin plastic was moulded in a bubble shape to clear the underlying support arms (see attached image). I have the frame from a '71 Caravel hanging in my toolshed just in case someone ever comes up with an easy and viable method of replacing the pane.
There are several other threads on this same topic and I do not believe anyone has had success in putting a new Lexan or other pane in the old frame. The frames on the newer rockguards are much sturdier and have a rubber gasket around the edge which seals against the body when closed.
Name:	71 rockguard.jpg
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 02-16-2006, 02:37 PM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Boy, the copper trim looks swell!
Michael
ArtStream is offline   Reply With Quote
Old 02-16-2006, 03:58 PM   #6
early's Avatar
We used alum. to fix our old rock guard. When we ever polish the AS it will match.
Dawn
Name:	email size airstream 009.jpg
Name:	email size airstream 010.jpg
early is offline   Reply With Quote
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 5 11-28-2005 07:49 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 07:22 PM
