Old 08-09-2007, 01:49 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Algae growing rock guard
This is what was inside of my rockguard when I opened it (figured it was an easy fix). I've cleaned up the window & recaulked, etc. Now I have to put the rock guards back on. They need new gaskets (where do I get them?). I would like to know how to prevent this green slime from growing again! It looks like it had an opening on the bottom for rain to drain out, but yuck!
Another question....The PO caulked the two rivets that I think are weep holes in the little gutters above the windows. Are they supposed to be caulked, or are they supposed to be open to drain water? I think it's the latter, but before I start digging the caulk out of the holes, I just want to double check. Thanks in advance!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-09-2007, 02:05 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If it's like ours the rivets are used to line up the window hook lip when you need to replace it in it's bracket at the top. They don't really do anything else. Ours are not caulked however.
Old 08-09-2007, 02:08 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Sorry about the picture....I guess I have to thin my file out or something. Won't let me upload.
Becky
1964 Bambi II
1988 Avion 32S
Old 08-09-2007, 02:11 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
The weep holes I believe are for water to escape from the window.
Old 08-10-2007, 11:55 AM   #5
Becky B.'s Avatar
1964 17' Bambi II
I upgraded to a contributing member, so maybe I can upload this picture of my algae window now......
Name:	front window with rock guard algae.gif
Becky
1964 Bambi II
1988 Avion 32S
Old 08-10-2007, 12:28 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Becky -- I suspect the contact of the gasket promotes holding moisture up against the skin. Are you storing in shade so that wetness doesn't dry up very fast? This is factor #1 IMO.
Light is the other contributing factor and allows photosynthesis and algae growth. This is not like mildew where you have residues and maybe use bleach or a disinfectant -- soap and water only is what I'd use. I'd try sponge-soaping the gasket too and not think of replacing it.
5 meter Langford Nahanni
Old 08-10-2007, 12:47 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Becky,
Gasket part number from Airstream is
Part # 685351.
Old 08-10-2007, 12:49 PM   #8
Central , Mississippi
Oh that's horrible. Take them off and I come pick them up to rid you of those horrible guards that are gooing up your pretty Airstream
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-10-2007, 08:51 PM   #9
Becky B.'s Avatar
1964 17' Bambi II
Part # 685351.
I thought these were an aftermarket item. The metal pieces that hold them in place are all rusty & falling out. I'll get in touch with Airstream & see if they have the same ones. They were like this when I purchased the coach, but it was parked in the sun with no trees around. I think water was trapped in there or something. Thanks for the advise & I think I'll keep them, HiHo!
Becky
1964 Bambi II
1988 Avion 32S
Old 08-11-2007, 03:18 AM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Becky,
I sent one of the parts folks your photo and it only took them about 5 minutes to respond with the part number. If they have the gasket maybe they still have the brackets too. Have fun.
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 5 11-28-2005 07:49 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 07:22 PM
Stone Guard/ Keep it or Remove it? 74Tradewind Rock Guards, Segment & Window Protectors 9 06-26-2002 01:09 PM
