Old 07-09-2017, 05:17 PM   #1
2008 25' Safari
New Albany , Indiana
Water Leaking
Hey guys,
Just bought a very very gently used 2008 22ft safari.
I hooked up the water hose to the city water inlet and water started pouring right out underneath the airstream.
Pulled up the false bottom of the wardrobe to access where the leak was and found that right where the water comes in the valve there is spewing water.
Anyone know what this valve is? What it's called? Cost to fix?
Thx
msmerideth is offline   Reply With Quote
Old 07-09-2017, 06:19 PM   #2
2008 25' Safari
Old 07-09-2017, 06:34 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Typically there is a pressure control valve at, or near, the fresh water inlet. It may be a part of that inlet fitting. The Airstream internals are designed for something around 40 psi. City water systems cal deliver 70 psi or more.
Where in the picture is the leak? Is the nut on the back of the valve tight? Is it or the valve body cracked? Is it leaking where the screws hold the back of the valve on?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-09-2017, 06:43 PM   #4
2008 25' Safari
It's leaking with high pressure from the yellow piece
Old 07-09-2017, 06:45 PM   #5
2007 22' International CCD
Time for a new one.
Old 07-10-2017, 06:26 PM   #6
2008 25' Safari
A new what is the question
Old 07-10-2017, 06:33 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
There are a few different styles, but I think this one
http://odmrv.com/catalog/index.php?m...roducts_id=902
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-13-2017, 03:19 PM   #8
2008 25' Safari
Thank you
Water Leaking at Wheel Well when water is hooked up Lauren25 Plumbing - Systems & Fixtures 18 12-28-2017 08:34 PM
Help! Water Leaking into my Fresh Water Tank dasams Fresh Water Systems 15 06-21-2017 08:57 PM
Water leaking from fresh water input 3dawgnight Plumbing - Systems & Fixtures 2 10-24-2016 11:01 PM
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
Water leaking when connecting city water- mystery hose nozzle Romelio Fresh Water Systems 1 11-16-2015 06:01 PM
