Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2008 Safari SE
Old 09-22-2010, 09:29 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
pipe/underbelly insulation
I have a 2008 Safari 23FB SE which was purchased this year. Going into winter, I am wondering what types of pipe insulation/heating this unit may have. I thought I read something about electrical wiriing to keep the pipes warm.
Anyone know definitively what is provided on the unit and how low the temps have to go before this insulation is no longer effective? We'd like to take the AS out later this October but don't want to risk pipe damage.
bonginator is offline   Reply With Quote
Old 09-22-2010, 10:32 PM   #2
_
each year,era, model and size may be different.
most models have ducting from the furnace to at least SOME of the tanks...
and most plumbing is INSIDE the living cavity.
keep the inside warm and the pipes survive.
NONE of the external plumbing is insulated or heated.
drain, freshwater inlet, exterior shower and so on.
so in freezing temps it is best to FILL the fresh tank for use...
then disconnect all outside hoses
and stay warm inside with the furnace rather than space heaters...
(some smaller units might be ok with space heaters if WARM enough.
then use the hoses only as need to REfill fresh or drain holding tanks.
_________
NOT ALL MODELS have ducted heating 2 the tanks.
for example your 23 doesn't.
it does have a 12v heating element 4 each tank.
_________
this is described in the owners manual as follows...
The furnace on Safari models except for the 22 ft. and 23 ft, models is ducted to provide heat to tanks and plumbing to prevent freezing.
The 22 ft. and 23 ft. models has 12-Volt heat pads installed with the fresh, gray, and black water tanks.
These pads are individually switched. This feature allows the saving of battery power in a dry camping situation.
To conserve battery power, RV antifreeze may be used to protect the gray and black tank.
Battery power will last about 3 hours using all three heat pads.
cheers
2air'
Old 04-25-2023, 03:40 PM   #3
2015 25' Flying Cloud
Euless , TX
2015 Cloud, Texas -2 degrees,
ice 1/4" thick on metal window frames.
Water constantly running, furnace stays on,
other than that I was pretty comfy. Oh, Door will not open, but I had beer.
2 days
If that helps
VacuumKing is offline   Reply With Quote
Aluminum underbelly missing Joe C 2002 - 2005 International 12 11-10-2021 08:55 AM
Underbelly and insulation campman All Argosy Trailers 8 11-27-2008 05:14 PM
Underbelly Skin Replacement Morning Dew Belly Pans & Banana Wraps 5 08-21-2003 09:12 AM
Underbelly Blues hex Belly Pans & Banana Wraps 3 10-24-2002 08:47 PM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
