Old 10-29-2008, 07:44 PM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Installation of mood lighting in my Safari
Hi all,
I had an idea to install some mood lighting. I suggested a lava lamp and
was shouted down by the wife... (something about me being lost in the 70's).
So here is my installation. I got the following items from Lewster for about $90.
  • ILMDL-WW-12LED warm white rope LED 12 v (quan 12 feet)
  • ILMDL-CONKIT-6, Connector Kit for 3/8" Incandescent or DC-Powered LED Rope Light (Connector, & 6' Cord) (quan 2)
  • ILMDL-END, End Cap (quan 2)
  • ILMDL-TRACK3 clear mounting track 3' (quan 4)
Attached is the result. I put them in the back and front of the trailer above the cabinets. Fine effect! especially in early morning. Good lighting for romantic candle light dinners!
Note the switch went in fine by taking out the panel in the rear and taking out the speaker in the front. Switch is a dpdt from Radio Shack. 1/2 inch hole. The closeup of the LED install is poor, but you can see I had to put
a piece of trim in front of the LED strip to prevent seeing the LED's from the trailer interior. Also, the channel was critical to keep the strip in place.
Make sure and test the rope light before installing. You have to insert a couple of prongs into the light from a fitting, and it is easy to miss them.
Also, if it doesn't work, reverse the wires. LED's only work with one polarity.
The "warm white" light is a little yellow, but it matches the wood on the
cabinets very well. Lava lamp would be best, but the reflection of these lights on the roof is outstanding!
ID:	70520   Click image for larger version
ID:	70522   Click image for larger version
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 10-30-2008, 04:47 PM   #2
Chalfont , Pennsylvania
Very nice!
shimmy is offline   Reply With Quote
Old 10-30-2008, 05:35 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Great job! Love the way it looks!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 10-30-2008, 06:10 PM   #4
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
That looks nice, good job.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 11:27 PM
Lighting SusanH363 Lights - Interior & Exterior 21 01-18-2011 08:03 AM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 03:03 PM
Lighting 87MH Electrical - Systems, Generators, Batteries & Solar 0 07-31-2003 07:18 PM
