Old 07-31-2009, 06:45 PM   #15
2000 31' Excella
Maryville , Tennessee
Have you all considered closing one room off and just cool the room you are in during the day ?
I closed my bed room off, worked great.
Then of course late evening open it up and let is start cooling.
Robbie R.
Robbie R. is offline   Reply With Quote
Old 07-31-2009, 08:13 PM   #16
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by Foiled Again View Post
I also heard of one owner who used a mister hose on the roof. by cooling the roof, he kept the inside cooler.
Paula
Boy, some things just never go away when you put them on the internet: http://www.airforums.com/photos/show...0&userid=17830
I used the foggers till I could get a new AC. See http://www.airforums.com/forums/f427...ead-40795.html.
The 15,000 Btu unit is an improvement, but I still am aware of hot days in full sun. Of course, the Excella is 34 feet, too.
Interestingly enough, the darker blue of the two I used when painting the shroud faded to an almost aqua color and is now the lighter shade. The lighter blue has not faded. Both were Fusion for plastic.
Vaughan
Old 07-31-2009, 09:32 PM   #17
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Thanks for the information Brian and Annette. I'll have to look for that stuff next time I'm at Lowes.
90+˚ are common in the west in the summer unless you get above 8,000' or more. And I heard it was 106˚ in Portland, Oregon, a couple of days ago. That's amazing. There's no escape.
Gene
Old 07-31-2009, 09:34 PM   #18
2009 34' Classic
Coburn , Pennsylvania
The product name is "Reflectix Insulation." See Reflectix Inc. | Home. Reflectix is made with two layers of 96% reflective metalized aluminum separated by a 5/16˝ enclosed air space. It can be purchased at Lowe's in various widths for standard residential construction, such as 16˝ by 25 rolls. Cut it to fit the dimensions of the portion of the vent to which it will be attached and either velcro it or simply cut it "oversize" and press-fit into the space.
Hope this helps.
flyfishntier is offline   Reply With Quote
Old 08-01-2009, 03:23 AM   #19
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my 25'er has the 11,000 BTU A/C and so far does the job. I have the small windows, mouse fur walls, and vinyl headliner. My A/C cranks out 40 degrees at the registers. If yours is 50 to 55 degreees, you may have a problem with it. Or maybe heat pumps don't go this low.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-18-2009, 08:27 PM   #20
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
Well folks I bit the bullet today and upgraded my heat pump to a 15,000 BTU unit. I hope to try it out this weekend while the temps are holding near the 100 mark here in North Texas. Will keep you posted and let you know how it handles the heat!
Snaken49 is offline   Reply With Quote
Old 08-21-2009, 08:01 AM   #21
Airstream01's Avatar
Land of fruits and nuts , California
Good info, looks like I'll be headed to Lowes to get the insulation for a preemptive strike on the heat.
Airstream01 is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Flamingo alert! yukionna Off Topic Forum 17 05-02-2005 08:42 AM
Hantavirus Alert! jjonesnc Off Topic Forum 17 04-06-2005 09:02 PM
WARNING!! Be Alert! Cedars On The Road... 31 03-30-2005 11:09 PM
Hello! (newbie alert) Travel_RN Our Community 14 08-14-2003 12:22 AM
