Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2008 Safari SE
Old 05-21-2008, 01:05 PM   #1
dmcclintock
Profile:  Texarkana , Texas
General Questions
When I retire next year the wife and I are planning on going full time for awhile. We originally planned on getting a 5th wheel but now are looking into going smaller and lighter with one of the 25 model Airstreams.
I can't seem to find any information on R value and construction and I would like some feedback on how these models do in extreme weather. I am a little concerned about all the windows and direct sunlite in high temperature conditions. Will the 13,500 BTU A/C keep up? Is condensation a problem when it's extremely cold?
Thanks in advance
dmcclintock is offline   Reply With Quote
Old 05-21-2008, 01:16 PM   #2
Roamin' Cat
Roamin' Cat's Avatar
Profile:  2008 25' Safari
Quiet Green , Connecticut
Rivet awnings
Hi and welcome
We are new owners of a 25FB and really love the layout. Our Safari did not come with the full awning package, so we ordered the streetside and end awnings to match and had them installed. We are very glad we did, and we haven't camped in hot weather yet. When the sun was beaming onto the streetside the heat gain from the windows was dramatically cut by lowering the awning.
I am sure more experienced members will speak to your other questions.
Cats
The New England Unit
Make no little plans; they have no magic to stir men's blood.
Daniel H. Burnham, Director of Works
World's Columbian Exposition, Chicago 1893
Roamin' Cat is offline   Reply With Quote
Old 05-21-2008, 04:03 PM   #3
n2916s
Profile:  1986 31' Sovereign
Miami , Florida
In the last two years we haved towed our 22 year old Airstream some 25,000 miles and have experienced a wide range of climate conditions. My peronal experience is that the 13,5 kbtu a/c is good for about a 20 degree change from the ambient temp. So, when we were in Las Vegas last summer and it was 116 degrees we spent a lot of time in the casinos... We also jury rigged an ice chest with a fan blowing over a 30# block of ice which helped get the trailer interior down to 85~.
The coldest we saw was mid-20's and were were toasty warm. With he A/C heat strip on full time, we were cycling the furnace about every 20-30 minutes. Lots of propane but it usually warmed up enough during the day that the heat strip would keep it reasonable without the furnace.
I have no experience with other types of rv's so I can't compare them.
Hope this helps,
mike
Old 05-21-2008, 07:01 PM   #4
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
We have an '05 25FB that we have spent 250+ nights in and have pulled 30,000 miles. We have camped extensively in both cold and hot weather. We have found the best accessory to keep the cold and especially the heat out of the Airstream is putting the silver windshield insulation between the curtains and the windows.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 05-22-2008, 07:14 AM   #5
dmcclintock
Thanks for the input.
Old 05-22-2008, 07:34 AM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
The 25' is a great size unit. The start of the widebody.
Having a 25' unit I can wholeheartedly suggest the following:
Do not get the non CCD/Classic windows. If you are new to Airstreams, you can tell the HEHR windows (the junk ones) by the outside, they have black frames. They leak air everywhere. The good windows are the ones that the whole window opens and closes and do not have a black frame around the outside of the window. The good windows are found on SE, CCD and Classic trailers. I custom ordered my Safari and was told no way they would upgrade (for additional price) the windows at the time of build, but that was 2004.
Get the second fantastic vent installed in the back. If you get the LS package on the Safari, or now called the Flying Cloud line, it comes with a spare tire and carrier, upgraded faucets and the front fantastic vent among a few other odds and ends included in the LS pkg. Having two fantasic vents really helps when you are in places without electricity and need good airflow inside.
Back in October 2003 I had pondered about paying the at that time $250 upcharge for the 15k BTU A/C unit. I had a 19' Bambi with an 11k BTU unit and it worked hard to hold it's own. Many folks here on the forum said it would be a bad idea. But then I looked at Airstream's own specs on the 25' Classic and found the 15k unit was an option for that. Since the 25' units are the same size no matter what 25' model you get, I went ahead and upgraded to the 15k unit, when my Safari was being built. The electronic controls for both the furnace and this A/C unit are excellent. In full sun and over 90 degree temps I can hang meat in my trailer if I needed to. The unit does not cycle more than normal as was said here that it would, nor is it overkill for a 25' unit. The 13.5k unit that comes standard is a good unit, but it is not anywhere near as good as the 15k unit. I would NEVER buy a 25' or larger without a 15k BTU sized A/C unit. It costs pennies IMHO to upgrade as it's being built, but costs a LOT more to swap it out later. Ironically, in the past few years, there have been a lot more 15k units installed in the non-Classic trailers. There were none that I found back in 2004 on dealer lots, and even some hesitation at the factory to put it into a 25' Safari back then, but they did it and now it is very common to see this sized unit installed....but, on the non Classic trailers, it's not on the menu, you have to ask for it special if you are ordering one.
I didn't go with the awnings all around and I think I should have. If I had to do it all over again, I might do all the awnings. Not because it is hard to cool the unit with the 15k BTU A/C unit, but it also shields the sun slightly making it less intrusive inside.
I would not suggest adding or buying any RV with a skylight. I have heard just too many issue with the domes, and since I think they still install vista view windows, there is plenty of light inside. If they don't come with vista views, I'd see about getting them. They are great. They were not available when I ordered mine, but I will say, if they were, I would have gladly paid an upcharge for vista views.
General Electrical questions LHall Batteries, Univolts, Converters & Inverters 7 08-07-2007 01:41 PM
The general went AWOL Gen Disarray On The Road... 54 08-01-2007 01:13 PM
general plumbing...etc (help me) roadtrip07 Plumbing - Systems & Fixtures 5 08-08-2005 08:22 PM
General Question on AS trailer Alex 1972 Ambassador 7 12-01-2003 10:06 AM
General Engine questions from a newbie ErichC Mechanics Corner - Engines, Transmission & More... 1 07-07-2002 06:23 PM
test
