Dry weight of Classic is substantially heavier -- I assume it is because of its solid wood cabinetry.
09 Specs according to Airstream.com
Trailer Model: UBW (dry weight) + NCC (stuff you can carry) = GVWR (Total Weight)
Safari 27FB: 5600 + 2000 = 7600
Safari 28: 5700 + 1600 = 7300
IntCCD 27FB: 5813 + 1787 = 7600
IntCCD 28: 5440 + 1860 = 7300
Classic 27FB: 6525 + 2475 = 8800
(Classic is not offered as 28' model)
All of the models above are almost almost identical in dimensions. (BTW, Did you know 27FB is LONGER than 28 by an inch?) Most likely, that they all share an identical frame. But Classic somehow is rated at substantially heavier GVWR.
Is it simply because of different elastomers used in Classic's axles, or does Classic indeed have different beefier frame?
