Old 10-03-2009, 08:29 PM   #1
2008 25' Safari FB SE
Spicewood , Texas
Unhappy entertainment package problems
This system with the on screen menues is driving me up a wall.
Can't get any local tv stations and with cable plugged in...nothing?
I have the antenna on air but when I scrool down to the signal strenth icon it just goes on by,it's not highlighted like the other icons.
The scan on air retrieves no stations and I know there are good signals in the area,my 22 ft. received stations fine,with the antenna down.
Can someone run me through the proper sequence..
thanks
kingfisher is offline   Reply With Quote
Old 10-03-2009, 08:45 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
You need to tell us a little more about your television. Is it the one that came with your Airstream? If your television was made in 2003, it is most likely not capable of receiving a digital signal without a converter box. As far as cable goes, you have to make sure that the antenna connection is turned off, and that the television is set to receive a cable signal.
Brian
SuEllyn & Brian McCabe
Old 10-03-2009, 09:51 PM   #3
2007 25' Safari FB SE
Blaine , Washington
With the antenna off, button on the wall next to the TV, and the inverter on, go to the menu, then settings, then scroll down to cable and hit enter or select on your remote until is says "on" next to cable.
John
Relentless is offline   Reply With Quote
Old 10-03-2009, 09:52 PM   #4
Blaine , Washington
If you want to receive TV via the antenna make sure the antenna is on and cable is off on the menu.
John
Old 10-04-2009, 02:12 PM   #5
Spicewood , Texas
up and running
OK,I was able to get it working thanks to your help!
Thanks so much,
Peace
iPod install with Entertainment Package Option - '04 22' CCD Xray Audio, Video & TV 28 05-15-2011 10:26 AM
What do you all do for entertainment? trucker101 Boondocking 45 04-05-2011 04:36 PM
Campground's entertainment... Safari Tim Our Community 15 08-05-2004 05:58 PM
Has anyone seen the "entertainment package"? Xray Our Community 0 02-28-2004 10:03 PM
Entertainment Rickk48 Off Topic Forum 11 01-11-2003 07:45 AM
