Old 10-06-2015, 08:06 AM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
Dome hand crank
the hand crank desintegrated,colonial A.Str can not find me a replacement,Comfort air does not sell parts....can not open or close fan..a good thing its in closed position..any ideas anyone??can not glue it back together....does not hold...???
la nomade is offline   Reply With Quote
Old 10-08-2015, 07:24 AM   #2
la nomade's Avatar
2018 22' Sport
replying to myself...for now i am using a wrench to open and close the fan...giving up all hope to find the hand crank...lots of you looked at the post..no one suggested anything!!!!
Old 10-08-2015, 07:38 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I bet you can fix that. Too much to type. See Private message.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-08-2015, 08:10 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Which trailer are you having the problem on?
If the 1990 I had my crank handle fail and Airstream told me they NEVER installed the crank, I did.
If the 1990 you can take the crank apart, drill out the rivets, and turn the gear 120 degrees and it will work.
2004 Excursion 4x4
Old 10-09-2015, 06:52 PM   #5
la nomade's Avatar
2018 22' Sport
fan
i have a 2008 safari sport...looks different from your photo...for now i use a socket wrench to open and close the fan,it works fine,i am still hoping to eventually find a handle....thank you very much for your input...M.V.
Old 10-10-2015, 07:52 AM   #6
HowieE's Avatar
Images: 12
By your model year Airstream no longer used proprietary vents so you should be able to find the handle, or at least the maker, at any large RV store.
2004 Excursion 4x4
Hand crank for stabilizers? SteveSueMac General Repair Forum 11 05-01-2014 06:47 AM
A-Frame Jack, front-facing hand crank? Splitrock Jacks, Stabilizers, Lifting and Leveling 5 04-19-2011 07:31 PM
Front dome crack davidz71 General Interior Topics 30 04-29-2003 10:18 AM
Fiberglass Dome Marshall44 General Interior Topics 5 03-10-2003 06:21 PM
What Color Dome? Dave-O Interior Restoration Forum 0 02-12-2003 02:41 PM
