Old 07-23-2018, 07:48 PM   #1
RichHog's Avatar
1972 23' Safari
Houston , Texas
Back Window Blew out
Was heading East after crossing Hoover bridge and at the next gas stop noticed the back center window was gone and some glass fragments left on the bumper. No idea of what happened if it was a bump in those Arizona roads or something smashing it from the air. Iíve checked the Vintage parts people and donít see the correct replacement. The top hinge still there and the side arms.
Anybody know best replacement option? This is a 2008 FB Safari LE 75th Anniversary Model. Thanks!
RichHog is offline   Reply With Quote
Old 07-24-2018, 05:50 PM   #2
AirstreamJim's Avatar
2007 25' Safari FB SE
Lake Worth Beach , Florida
You might try an Airstream dealer, or calling JC. It's probably the same window they're still putting on 25FBs currently and should be readily available (but likely expensive...).
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 07-24-2018, 06:32 PM   #3
Kensington , Maryland
Something very similar just happened to me. I'm pretty sure that we failed to lock both locks and the window popped open violently at some point.
Lightning struck and Colonial Airstream, NJ had the window in stock to my doorstep in two days. Dang.
Best of luck.
PS - easy to replace the window. Ten min. job.
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 07-24-2018, 06:38 PM   #4
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
We had the same window broken out of our 2009 25' FB. What caused our failure was not securing the window during a wind storm. The window flapped in the breeze until it shattered
Our local Airstream dealer had the window on the shelf so for $240 we were healed up next day.
Understand you are travelling so a call to the AS dealer the way you are going might be the ticket. I've heard good things about the dealer in Albuquerque, NM (assuming you are eastbound from AZ).
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 07-24-2018, 10:40 PM   #5
RichHog's Avatar
1972 23' Safari
Houston , Texas
Thanks for the information. Probably that is what happened.
Old 08-04-2018, 08:26 AM   #6
RichHog's Avatar
1972 23' Safari
Houston , Texas
Still working on the replacement. Airstream uses many different windows on their trailers. Have Inland Airstream working on it with Airstream.
1997 Excella bedroom window blew out KCG Windows, Doors, Locks & Vents 3 10-03-2017 05:26 PM
Here is area tire blew out & needs repair starcraft Belly Pans & Banana Wraps 7 02-10-2012 07:50 PM
WOW....I just blew past 2000! lewster Off Topic Forum 23 10-04-2007 10:14 AM
blew my 110V breaker - where is it wavemaster Electrical - Systems, Generators, Batteries & Solar 3 10-24-2006 07:33 AM
tire blowout blew hole in wheel well munimula Roof 16 06-03-2006 10:05 AM
