Old 08-25-2011, 11:15 AM   #85
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
But is it worth the extra money for a 27'?
Gene
CrawfordGene is offline   Reply With Quote
Old 12-17-2011, 01:47 PM   #86
Looking for 23/25/27FB
Odessa , Texas
25FB vs 27FB - if any of them are legal in Europe/UK ?
I have a similar dilemma choosing between 25FB vs 27FB. My major concern is if they are legal in Europe and can be registered in the UK. If not, I would go for 27FB.
The UK legislation says that trailers and caravans towed by vehicles with a Maximum Authorised Mass (MAM, known as maximum permissible weight or gross vehicle weight) of 3.5 tonnes [7700lbs] or less are limited to a maximum body length of 7m [22' 11.6''] excluding the coupling and drawbar and a maximum width of 2.55m [8' 4.39''], unless it has an Individual Vehicle Approval (IVA) certificate. A vehicle with an IVA can have a maximum width of 2.6 metres [8' 6.36''].
My questions are following :
1. Does anyone know the official length of both 25FB and 27FB EXCLUDING the coupling and drawbar, but INCLUDING the rear bumper ? (The official drawings from Airstream with dimentions of both 25FB and 27FB would help a lot and would be highly appreciated).
2. Which of 25FB built 2005 onwards (except Classic, due heavier weight) are available in Twin Beds configuration, i.e. Safari, Flying Cloud, International, Ocean Breeze, Serenity, Signature) ?
Many thanks to all of you who know the answers and give their valuable input to clarify this matter !
Timofeevich is offline   Reply With Quote
Old 01-19-2012, 10:04 PM   #87
2007 25' Safari SS SE
St. Louis , Missouri
Hello R,
My wife and I have a 2007 Safari SS SE and love its size for towing. I pull it with an '07 F150 and a fairly big cargo load in the bed (tandem recumbent bike with paraphernalia, heavy tools, etc. When I read that you are trying to figure out what can easily be stored on your property I decided to share our setup and constraints: We live on a narrow residential street with a 10' wide driveway and little clearance on either side. Our rig has to be backed all the way down to the rear yard, so it is a tight fit. I took an aerial photo of our house/driveway with a crude scale overlaid on it to our dealer for a serious discussion before buying our Airstream. We were told that it would be no problem getting the 25 SS in. And, after two full seasons during which we made about ten trips, we have essentially had no big problems backing it in. I'm not saying I can get it back there without going backward and forward several times; but I have not been disappointed in the operation and it typically takes 15-30 minutes to get it into its nest. I don't know if a 27 footer would fit. Keep in mind that although the 27's axle may or may not be farther from the tow vehicle, there will almost certainly be more overhang at the rear and that could hamper your manouverability during backing. Hope this helps, and good luck with your decision.
Hi Ho Silver
Jim Pona is offline   Reply With Quote
Old 01-20-2012, 05:18 PM   #88
Home of Vortex tuning
CDONA's Avatar
Sedona , Arizona
Question 2,
Current brochure indicates, 25 FB Flying Cloud has the only optional twins.
Glad I checked first, I thought I knew all the differences of this raging 25/27 controversy
I going to pop for the EB Extended, a 27 FB, no twin option.
"Wayward" in Hope Az.
CDONA is offline   Reply With Quote
Sleeping Accommodations beyond the queen bed in a 25FB or 27FB MaryD 2008 Safari SE 10 04-13-2010 10:54 AM
25FB Shower Stall Seat AZ-JH 2006 Safari 5 12-15-2008 06:01 PM
International 27FB or 28W? koebe 2007 International 11 07-27-2008 01:17 AM
New 2007 International Ocean Breeze 25FB NeatAirstream Commercial Listings 0 12-15-2006 07:39 AM
New Safari 25FB BeBop 2005 Safari 6 03-03-2005 06:30 AM
