Old 07-15-2011, 10:13 AM   #1
Sphere Guy's Avatar
Livingston , Texas
14" to 15" wheel & tires upgrade?
Have any late 2008 or later 23 ft Safari owners upgraded from 14" to 15" wheels and tires?
I'm looking for more ground clearance, etc..
Will they fit in the wheel well?
Is availability /popularity a problem for the 15" size while traqveling in case of needed replacements?
Will 10" hubs be sufficient to handle this size upgrade?
Thanks for all responses in advance.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 07-15-2011, 10:15 AM   #2
Goal15's Avatar
Holly Lake Ranch , Texas
Will be interested to see where this leads as my 2006 has 14 inch wheels and tires which seem to limit availablity of tire choices
Goal15 is offline   Reply With Quote
Old 07-15-2011, 11:07 AM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
You can upgrade to 15 or 16 inch but in either case you will have to get new axles since the rims are 6 lug.
Al - K4GLU is offline   Reply With Quote
Old 07-15-2011, 11:39 AM   #4
Sphere Guy's Avatar
Livingston , Texas
I've found a few 15" wheels that are 5 lug 4.5 bolt pattern.
I've measured my wheel well internal dimensions but still can't determine if they will fit. It looks like it but really don't want to go thru the purchase $$$$'s for a mock up to have them not fit.
I do know that 16" will require new hubs, which means more $$$'s but don't need the extra load capability on my 23 ftr.
Sphere Guy
AIR 50601
Old 07-15-2011, 11:46 AM   #5
SteveH's Avatar
Common Sense , Texas
You can check the tire size on line, compare to the size of your existing tires/wheels, and see if you have the needed additional clearance. Try tirerack.com
Regards,
Steve
Old 07-15-2011, 11:57 AM   #6
Here is a link to a tire size calculator:
Tire size calculator
Old 09-06-2013, 10:00 AM   #7
2008 23' Safari FB SE
Lompoc , California
Has anyone come up with a resolution to this question? Without going all in, dimension charts would indicate that a 225/75-15 tire would fit in the wheel wells on a 15" X 6" 5 bolt X 4.5" pattern, allowing slightly less than 1" increase in ground clearance and D rated tires.
Anyone?
KLEVELANDER is offline   Reply With Quote
Old 09-06-2013, 12:20 PM   #8
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
5 x 4.5 bolt pattern wheel should be very easy to locate. Very commonly used on ford and dodge vehicles.
panheaddale is offline   Reply With Quote
Old 09-08-2013, 04:18 PM   #9
Lompoc , California
Sorry, I should have been clearer; the original question was 'will the larger wheel/tire combination fit in the Safari 23 SE wheel wells?'
Has anyone actually tried this upgrade?
Old 09-08-2013, 04:47 PM   #10
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Check here.
http://www.airforums.com/forums/f438...-lt-96716.html
tinbender is offline   Reply With Quote
Old 09-11-2013, 07:48 PM   #11
Lompoc , California
Originally Posted by tinbender View Post
Okay tinbender! That's good info. Can we make the assumption that the wheel wells on a 2011 23' FB International are the same as on an '08 Safari SE? Picture looks similar. . .
thanks
Old 09-12-2013, 07:29 AM   #12
tinbender's Avatar
2001 16' Bambi
K,
I don't have first hand knowledge of them being the same but based on others from the forum that I have read about who made the switch from 14 to 15 on 23s, I would say probably. Several model years were covered in those postings including 07/08 range. Before spending any money, you could always call the ultimate source for the best answer, Airstream service center at the Mothership.
That's what I would do unless fortunate enough to have the 2 of them side by side for a measurement. The swap out won't be cheap so much better safe than sorry here.
Good Luck,
tb
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
