It's the end of March and hopefully you're out on the road and have gotten your leak fixed. Out in the SW, not much rain, but we did have some over winter and lots of snow, and no leaks so far. I hope our luck continues and yours gets better. We are finding little things that need fixing—like the propane tank cover rests on some wires and wears the insulation off. I fixed that with a pipe clamp over the wires. One the the locking catches for the stove fan vent came off. When we make a list to take our unit to the dealer I'll post the problems.
We have taken our first two weekend trips in the SilverLining. We went to agility trials with our dogs, so it was not really the type of camping that you do when exploring interesting places, but it was great!
The first weekend we had water and electric hookup, so we did use the water tank and pump, but we tested it out at home a bit while flushing out the antifreeze. During that process, my husband accidently ran some of the antifreeze through the filter at the sink for a minute or two. Now I am not sure if we should trust that water filter anymore. We used bottled water that we refill from home for our drinking water, (and for the dogs of course!).
We really felt very comfortable, and love the floor plan. It has a nice amount of floor space which is very important with two big dogs. I hear they have discontinued the SS floor plan, so I am very glad we got this when we did.
One issue we found is that the sensor seems to be off for the black water tank. It reads full when we have only put one gallon of water and the chemical down the toilet.
We also had a flood before the second weekend out. We did not have water at that show site, so when filling the tank, it overflowed a little before my husband shut off the hose, but that ended up putting a large amount of water into the trailer, leaking out by the sink. I called the dealer, and our salesperson was helped us to identify where to look for a problem, but we did not find any loose connections. We will have to be very careful when filling the tank.
A few other minor issues, like a missing bracket on the stove vent, and the fantastic fan does not always want to open, but overall we are very pleased. Missing silicon cushions on some of the cabinets, which we took care of.
As far as the leak we had during the rain over the winter, it has not happened again, and we have not had the trailer back to the dealer yet to check it out. I wanted to get a few weekends of use in, so that we could find out if there are any other issues to be corrected.
I would also like to mount another towel bar, but we are afraid to drill into the bathroom door, as it is so thin. The one towel bar is in the shower, and it would be good to have another on the inside of the door. Any suggestions would be appreciated. I have been looking for something similar to what is in the shower, but glue on, instead of screw in.
We will be going to another agility trial this weekend, and I will try to take a few pictures and post them.
Diane
Propwash Day High Stickeen, MX, MXJ, NF
Wyemede's Min Bamse Brakar, VSB, (Very Spoiled Brat)
Over the Bridge,
Ch. Nsk's Bjorn von Jotunheimen, CD, ND
The antifreeze is nontoxic and the filter is supposed to filter things out, so I would think it would be ok, though if it were us, I'd be wondering too. If you see no pink water, it should be ok. I generally use distilled water for drinking anyway (no salts). The filters are expensive to replace too. When winterizing and dewinterizing, remove the filter. There's a valve that closes when the filter is removed and it shouldn't leak while you're running antifreeze or flushing the system.
There should be some paperwork telling how to reset the sensors. It is easy to screw up the settings for them without realizing it. If I recall correctly, pushing that middle rocker switch at the wrong time can be a bad thing—then you have to reset everything. I just glanced through the instructions since ours seem to work fine, and resetting looked confusing. You can probably figure them out, or ask the dealer.
I always overfill the potable water tank—I fill it until it overflows on the ground and we haven't had any water come out of the faucets. Unless you create a seal with the hose filling the tank, water should just come out around the hose. There should not be enough pressure to force water out anywhere inside the trailer. If you seal the inlet and hose somehow, it would force water through the faucets if they are open. You should try to duplicate the leak doling the same thing again because these things usually don't fix themselves (but if there's a rubber seal, it might have been dry and had to get wet to expand slightly and seal better). Now you know where to look. If they are compression fittings they may need a very slight tightening, but be careful because too tight can destroy the seal (I know from experience). It would be either a rubber or neoprene seal or a round metal ring. Another warranty item?
I think you can oil the fan door (I think it says to do it periodically in the owners' manual), but I haven't because I am avoiding climbing onto the roof.
The towel bar issue. The bathroom door is thin and may have a fiber core. Fiberboard doesn't hold screws well, so I would avoid that. What kind of facing is on your door?—if it's a thin veneer, it may not have the strength to hold a towel bar (wet towels are heavy and putting them on it and taking them off stresses the connection). I did put a double clothes hook on the inside of the closet door without a problem. Just be sure to measure the length of the screw while in the hook or towel bar because a 3/4" screw is often only 3/8" or maybe 1/2" into the wood. You can get a longer and fatter screw, but make sure it stops before it's just below the surface on the other side because it can push up a little bump on the surface and you'll see it every time you walk by. Use a coarse instead of fine thread in fiberboard.
We used big suction cup hooks in several places—for robes, towels—and they generally stay up, but eventually fall down after a while (days when I do it, months when Barb puts them up—I haven't mastered those things). These are big plastic things where the hook acts like a lever to tighten the suction bond. There's a thread somewhere on the evil towel problem. There are many hooks that stick to the surface, some have better glue than others. I mounted two hooks on either side of the bathroom door inside the bathroom—there are several layers of wood or fiberboard with veneer there and it's thick enough to support a lot of weight.
Watch carefully in drilling into anything where you aren't sure of what's on the other side. There could be wires, pipes or the shower walls. There's a lot crammed into these trailers. I haven't mounted anything with screws into the inside of the exterior walls—not only do I not know what's back there, but the drill bit tends to create voids in the insulation. But if I wanted to, I'd follow the rivets because I think that's where the steel frame is. The suction cups work best on aluminum.
Glad to see you're enjoying your baby and I hope there are no more leaks.
Thanks for all the information Gene. You are becoming quite the pro!
We did try to recreate the leaking we had when filling the tank, but could not do it. We only let it overflow for 20-30 seconds, so I suspect that when my husband did it, he left it longer, but he will never admit that.
We had quite a bit of water inside, the rug was completely saturated, and water kept seeping out in the corner below the microwave. Our water input has an overflow valve, and when we tested it, the overflow water came out of that just fine. The water did not come out of the faucet, it was somewhere under the cabinets where the input plumbing is. I know he had done it the same way with the old trailer, but it never overflowed into the trailer.
I did buy some of those suction hooks you are talking about. I also have one of the 3M hooks. They use an adhesive that is supposted to be removable if you change you mind. That works well for a towel by the bathroom sink. The one I have is supposed to hold 5 lbs, and has a wide flat hook. Maybe two of those would work well for the back of the bathroom door, and you could hook the towel to both of them to keep the towel open to dry.
This weekend we have another show where we will not have water or electric, so we will need to use our new generators. We bought 2 Honda 2000's. Depending on the weather forecast, we might just bring one alone. We used to use a Honda 3000, but my husband was tired of the weight. They are very heavy.
I will look for info on resetting the sensor, and check into oiling the fan.
Did your dealer say anything about putting silicone on the window rubber? I think they told us to do that when the weather warms up.
Diane
Over the Bridge,
I think I read about silicone somewhere. I've done it twice. Some of the windows stuck so badly I couldn't open them, so I took a broad putty knife and very carefully pried them loose. I wish they had a metal edge at the outside edge of the windows to make them stronger.
Good about the water leak, I guess. I'd sure want to know how it happened to make sure it doesn't happen again. And always believe your husband. Husbands are never wrong (somehow my wife doesn't believe that, I don't know why).
Robert, thanks for the tip on the tune up grease and advice on the bulbs and screws. Hope you get that last MAJOR real soon!
2Air, not sure if we have a leak to fix. Once we cleaned up the water by opening the 'service door' under the cabinets, where the hot water bypass and water intake pipes are, we did not have any more water leaking. However, when we pulled out of the drive way, some water came out of the low point valves under the trailer for a few minutes, so water must have been under the tank also. Our water level did not drop, so our fresh water was not leaking anymore. Anything else we should check?
Thanks so much for all of your advice.
Diane
Over the Bridge,
We very carefully filled the tank last night for our weekend trip, with my husband in the trailer, head inside the cabinet , and me with the hose. I pulled the hose it out as soon as it started to overflow, and also had the hose set with not too much pressure.
But we still had a leak. It looked to my husband like the main intake pipe inside the trailer has a hole in it, because even before it was totally full, the leak started. It is kind of hard to see exactly where is is coming from, water is running down the large input pipe onto the floor inside the cabinet.
We have an appointment this week to take it in for service. Hopefully they will find and fix the issue! I will make a list of the other issues, none of which are major, but I would like the sensor on the black water fixed.
Diane
Over the Bridge,
