Yes, I think it was that Christmas classic, a DVD on Airstreams, an long running infomercial. I really did not watch any of it though, I was too busy admiring the AS!
I could not spend the night, she is winterized, so we would not have any water, and I could never sleep without my dogs .
The day has finally come. You must be excited to finally bring your big silver "baby" home. We're certain it will be all you have wished for. Good Luck! .............Cheers!
Cheers
2008 27 FB Safari SE "The Martini Shaker"
Well, the SilverLining is home! And she is looking good!
A few issues, the 10 disc CD changer does not work, but I can put a CD in to the system and play that way, should have had them demo that.
Another more annoying problem we are having tonight, the propane warning buzzer keeps going off, it shows fault, (yellow) not red, but I cannot get it to stop. We tried to turn on the Heat Pump, but it would not come on, maybe too cold, so we put the furnace one, (family coming over to see, so we needed to keep them warm). I know it takes some time to burn off the fumes,but the noise of the alarm is freaking out my dog. He does not want to go outside, because the SilverLining is close to the house and he can hear it.
Any ideas of how to stop the alarm would be appreciated.
What a fun day it was!
Diane
Propwash Day High Stickeen, MX, MXJ, NF
Wyemede's Min Bamse Brakar, VSB, (Very Spoiled Brat)
Over the Bridge,
Ch. Nsk's Bjorn von Jotunheimen, CD, ND
2Air,you are the best, I will check out the thread you recommend.
Over the Bridge,
...snip....
Another more annoying problem we are having tonight, the propane warning buzzer keeps going off, it shows fault, (yellow) not red, but I cannot get it to stop....snip...
Diane
Diane...Sometimes when we ran the furnace in the past, we'd get that fault signal and that incesant beep from the LP detector...our dogs get freaked, too... You probably know this, but you can reset the detector so it goes back to the "green" mode and is operable. We talked to our dealer about it and they said in new units, the detector may be picking up fumes from the new furnace and that's what's causing it, since it only happened when the heater was running. It is very sensitive...we have set it off with aerosol room freshner and once one of the dogs was lying near it and f*rted...and it went off! You might also try gently blowing out or vacuuming out the sensor intake hole on the front of the sensor...it may have dust or other accumulation of stuff in there that is causing it to go off or fault out.
And I will also pass along that we did feel like there was a gas leak that was elusive, but was becoming more and more noticable on our last trip...in our unit the furnace and the range ae fairly close, so we didn't know where it was coming from. We did determine there was in fact a gas leak because when we smelled it we turned off the tanks and bingo, the smell went away...we took it in to the dealer and sure enough there was a leak in one of the stoce-top burner turn-on vlaves...slow, but a leak nonetheless...so if you do smell any gas have it looked over...
Good luck with your new AS...you are going to love it...well...you already do, right?
TB
TB & Greg...and The Girls, Annie & Sadie
Yesterday was quite the exciting day. We awoke to find about three inches of show on the ground. Not totally unexpected, but we had hoped the forecast was wrong.
Our trade in trailer was in the street already, since my husband had been busy raking out the tons of gravel to extend the trailer pad. We were planning to leave around 8:30 AM, but took our time to give the roads a chance to clear up. Then we found the door to the compartment that we store the sway bars in frozen shut. Waited a little longer, hoping the sun would melt it, but had to resort to pouring hot water on the door to get it opened.
Finally on our way around 9:40, the roads were fairly clear, and we knew they would get better as they did not get much snow up at the dealer. We made it there safely by around 11 AM. As I steped out of our van, I almost wiped out on a sheet of black ice in the dealer parking lot, but luckily I did not fall down. They quickly put more salt on the area.
Lauren gave us a through walk through, but we opted not to put water in the tanks due to the cold weather. The tanks were emptied, and the tech and my husband winterized the unit together. The service manager gave us a bypass hose for the water pump, and we were please to find that it is not too hard to get to the water pump in the SS model.
Another technician went over the Hensley Hitch with my husband while I stayed indoors to keep warm.
By 2:30 we were ready to begin the ride home. It is very hard to pull out of the dealership, especially with the traffic this time of year. But after about 7 minutes, we got a break, and were on our way. The ride seemed stiffer to me than with our other trailer, but once we hit the highway, it seemed fine. We had to stop about 50 miles into the 70 mile ride home to adjust a few things on the hitch. My husband was saying I do not see why I have to do this, but I said just do it if they told you to do it. I kept thinking I should have listened to the Hensley Hitch information .
At home pulling into the driveway, and back to the pad, (behind the fence) went well. I was concerned about hitting the sidewalk, as we did with the other trailer. We put the boards down just to be sure, but I don't think we would have hit anyway which is very good. I have heard that with the Hensley backing up is a little different, takes a little longer to respond to changes in direction, more like a fifth wheel. But it went quite well for the first time. Not so well when he unhitched. He forgot to put the tongue (or whatever you call that) so when he pulled the van out, the trailer droped down on the hitch. Luckily his 85 year old Aunt and I were sitting down inside, and with the new unpacked gravel, no harm was done to the hitch. Don't think he will make that mistake again.
I will take some more pictures tomorrow and post them.
2Air, regarding the heat pump, we were plugged into a 30 AMP outlet, which we had installed by the trailer pad a few years ago. I think it might not have started on the heat pump because it was so very cold.
TB, thanks, found that the reset button on the propane alarm must be held in for 5 - 10 seconds to reset, then all was quiet and the dog stopped shaking
And I figured out how to work the 10 disc CD changer today. It works just fine.
Diane
Over the Bridge,
Just a note, when you first switch on the thermostat and call for air conditioning or heat from the heat pump, there will be a delay before the start of the unit. I think its more of a situation of the timer that is built into the thermostat which prevents the compresssor from starting too soon after either a normal cycle or a power interruption. At first this used to drive me crazy but the more I though about it I realized that this was the protection cycle that was causing the delay.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
