Old 09-10-2011, 07:52 PM   #1
1981 31' Excella II
New Market , Alabama
Just Bought a 31ft 1981 Excella II
Well I just bought my first air stream. It seems to be in great shape for it's age. I will post some pics when I get a change. Exterior is clean and the interior is dirty but all original and seems to be relatively intact. There is no floor rot or rear end sag. It is the center bath model with twin beds in the rear.
Perry
Old 09-10-2011, 08:04 PM   #2
SteveH's Avatar
Common Sense , Texas
Congradulations on your new trailer. I know you will enjoy airstreaming.
Regards,
Steve
Old 09-10-2011, 09:04 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Congratulations! Happy streaming!
Lance
Top is offline   Reply With Quote
Old 09-11-2011, 07:06 AM   #4
1981 31' Excella II
Thanks for the warm welcome everyone.
Here are the pics that the seller took. I will take some more tomorrow. It needs some little stuff but overall it is in good shape. I would grade it about a 90% outside and maybe 80% inside. The inside stuff is easy though. All the awnings work and there are awnings on every side. It has been replumbed with PEX and I hope it don't leak. The fridge and AC work and it supposedly has a new water heater. The control panel for the tanks seems to work. Not a bad trailer for $5k.
Index of /AS-Temp/81-ExcellaII-31ft
Perry
Old 09-11-2011, 11:48 AM   #5
Ottawa , ON
Perry,
Wow, that IS a lot of trailer for $5k! Looks like you got a fabulous deal. The interior is usable, but the stuff you may wind up changing looks to be all the fabric stuff, and that isn't terribly hard work, IMHO.
Way to go, we look forward to hearing lots more about your Ex!
Old 09-11-2011, 12:52 PM   #6
1981 31' Excella II
Well not so great a deal. The floor is rotten in the back. It looks like the bumper seal leaked and rotted the last foot or so of flooring. The rest of the floor in the trailer looks good. I will post some pics soon. At least it is not particle board. I have all the rear beds removed at this point and now the depression sets in. I can fix it but one can only do so much at a time.
Perry
Old 09-11-2011, 12:57 PM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
That brings back memories! Looks almost exactly as I remember my parent's first AS looked like. It too was an 81 Excella with rear bedroom and side bath - had a double bed though. Enjoy!
Kay
Old 09-11-2011, 01:47 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
welcome to our world. The floor rot and and all that is typical and what we all go thru with any older Airstream. So you are now in the club! When you tear out some floor and see the frame, then the next repairs will be planned. Hopefully your will not be too bad.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-11-2011, 01:54 PM   #9
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
Nice Trailer !,Its great you found something that nice in your price range.
Airline is offline   Reply With Quote
Old 09-11-2011, 02:08 PM   #10
1981 31' Excella II
Here are the pics of the floor and frame. The pink fiberglass stuff is going bye bye for now. I am eventually going to put 2" thick rigid foam in there and glue it to the sub floor. I don't want to pull the skins yet if I can help it. The holding tanks are supposed to lean towards the dump valve?
Index of /AS-Temp/81-ExcellaII-31ft/Floor-Repairs
Perry
Old 09-11-2011, 03:22 PM   #11
Perry
Perry.
Since your going this far with your rebuild, I would suggest that need to or not, check out everything and make "SUPER" sure that all is OK. If not, make sure that it is.
The long term benefits are huge, and it saves using those nasty 4 letter words.
Old 09-11-2011, 04:19 PM   #12
1981 31' Excella II
I have checked the remaining floor and it looks good accept a little from the door area. The rest of it is sound. Water system is ok for the moment. I am going through the rest of the systems as I get to them. I need to really check the gas system because it has been messed with. I am going to need a coleman AC shroud soon.
Perry
Old 09-11-2011, 07:51 PM   #13
Minno's Avatar
1972 31' Sovereign
You do want there to be a slope down to the dump valve. ( A little slope - about 1/8 inch per foot for pipe, 1/4 inch per foot for the black tank itself, Chris says). If everything is totally level it won't dump properly. On our trailer, the black tank was sloped by the rigid foam insulation underneath it to the valve. We duplicated that when we installed the new black tank with new rigid foam.
Kay
Old 09-11-2011, 08:04 PM   #14
1981 31' Excella II
Well the reason I asked was because the sheet metal boxes that cover the holding tanks are leaning towards the dump valve. I take it that this is normal and the boxes are not coming loose?
Perry
Excella :: 1981 Airstream 280 Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
1988 Airstream Excella 31ft Travel Trailer eBay Watch Airstreams on eBay 0 07-25-2011 05:40 PM
Vintage 1981 27ft AIRSTREAM Excella II Travel Trailer eBay Watch Airstreams on eBay 0 04-23-2011 08:10 AM
Just bought 1990 excella brake question safariuser Brakes & Brake Controllers 2 02-23-2011 03:30 PM
