Old 08-05-2013, 02:02 PM   #1
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
"Wormy" Alu/wheel fix
I've seen talk of this on these forums but can't find it.
The failure of the clear coat finally sent me round the bend and this is my "fix"
First sanded with 220 to remove clear coat = 20min ea.
Masked = 25min ea.
wiped with Denatured Alcohol 2min ea.
3 light coats Zinc Chromate yellow primer
2 coats Rustoleum truck bed liner paint (I like the semi-gloss textured look) and it should be tough enough.
Next are those darned door hinges!!
ID:	192505   Click image for larger version
ID:	192507   Click image for larger version
Del Gurney is offline   Reply With Quote
Old 08-06-2013, 04:52 AM   #2
LFC
Memphis , Tennessee
It'll look good until the paint starts coming off...
LFC is offline   Reply With Quote
Old 08-06-2013, 06:32 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Great touch!
Don't power hose... And a yearly touchi should be easy with light wet sanding first.
For shiny aluminum I use Flitz or similar polish. One nasty job then easy to keep up, even on my motorcycle engine rocker boxes.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-06-2013, 07:41 AM   #4
TinLoaf's Avatar
2016 30' Classic
Trenton , Illinois
Images: 22
Looks good. Could you post a photo of what the wheels look like on your trailer when you get a chance?
Steve
TinLoaf is offline   Reply With Quote
Old 08-06-2013, 01:45 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
Looks good!
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 08-15-2013, 01:10 PM   #6
Del Gurney's Avatar
1965 26' Overlander
Finally done
Here's a pic of the wheels back on Tinbad.
Note that I also painted the light lens covers, door hinges, furnace door, water door, stove vent and rock guards with the same paint (but different primers).
TOO MANY different grey's.
Oh, I also painted the bumper and tail light lens covers black.
THE CONTRAST IS REALLY STRIKING!
So this finishes the "under carriage rehab" that involved dropping the belly pan and wraps, the water tank and painting the entire frame, axels and every thing else from stem to stern. Also re-placed what little AS installed in the way of insulation.
Other work I've done is replace the skylight with a marine grade hatch. Improved on the Bumper Storage with a custom design. Replaced every gasket and all screws are now SST on exterior. New carpet in the BR. And on and on.
You'll notice that I went with a marine grade Grey that better matches the silver.
Time to sell it and find a new project trailer b'cuz I'm already board.
