Old 02-24-2008, 08:19 PM   #1
1976 Argosy 24
Santa Clarita , California
Question Will these wheels fit my 1976 Argosy???
Wheel Specs:
14 x 6 Aluminum
Bolt Pattern: 5 on 4.5
GVW: 1900 LBS
MAX PSI 50
Overall Width: 7 Inches
Backspace: 3.5 Inches
Offset: 0
Center Bore: 3.14 Inches
Valve Stem: TR413 Pull in Rubber Valve
MAX Torque: 110-120 FT LBS
AndyPenny is offline   Reply With Quote
Old 02-24-2008, 08:23 PM   #2
. , At Large
No. You have 6 on 5 1/2" wheels, 15" diameter, and somewhere over 1900 pounds per wheel load rating.
Old 03-02-2008, 02:30 PM   #3
1976 Argosy 24
What is the Center Bore on the 15"(x6", I presume), 6 on 5.5", 0" offset wheel? Can the offset stay at 0" if I go to a 15"x7" wheel?
Old 03-02-2008, 02:57 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Andy,
This is one source of many for the 15X6 wheel with 0 offset:
Trailer Parts Superstore - 15" 6 on 5.5 Lug Aluminum Trailer Wheel
or this: 15" SIX BOLT ALUMINUM TRAILER WHEELS FOR TOWABLE RV'S, FIFTH WHEEL TRAVEL TRAILERS, BOAT TRAILERS, CARGO TRAILERS, HORSE TRAILERS AND MORE
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 10 06-02-2023 12:21 AM
Contemporizing 1976 Argosy D - opinions please SmokelessJoe All Argosy Trailers 739 05-22-2017 09:24 PM
1976 Argosy pyoung Member Introductions 1 01-04-2006 01:25 PM
1976 Argosy 24 breakaway Tires 3 11-27-2004 06:25 PM
