Old 03-23-2007, 07:23 AM   #15
87MH's Avatar
1978 31' Sovereign
Images: 292
[quote=PizzaChop]Dennis, I'd be curious to know what you did.........quote]
Ron:
Purchased the studs below:
Champion Trailer's webpage for hub lugnuts
IIRC, when I talked with Champion, they had several different stud lengths in stock.
I purchased the acorn lugnuts from the rim supplier to insure the proper cone angle for the seating area milled into the rims.
Champion Trailer is another company I trust to do business with over the phone....they will let you know if your order is in stock or not, and ship every day, as far as I can tell. So far everyone I have talked with was well familiar with their products and stock.
Hopefully, as Beginner indicated in the previous post, "Locktite" will keep the studs in place, but, from experience, there is usually one of the group that backs out where it's not supposed to.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-23-2007, 07:36 AM   #16
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Well, I guess I feel a bit more sane after reading this thread. The few mechanic friends I talked to before I started thought I was nuts (no pun intended). I did not know that you could order the studs ready made. (A little more expensive than my method but less time consuming.) Also, if you can trust red loctite alone, you don't have to remove the hub.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 03-23-2007, 10:38 PM   #17
1984 31' Excella
Norfolk , Virginia
Images: 11
Stud Conversion
You will have to call Southwest Wheel Co (1-800-866-3336) to get a price, but, when I ordered mine )02-15-2006) the studs were $0.72 each and the Chrome Acorn Nuts, long were $0.42 each.
I had them tested for hardness (rockwell) and tensile and they were a little harder than the lug bolts I removed and had a tensile strength higher ( withstood more pull before breaking) than the lugbolts.
Beginner
Beginner is offline   Reply With Quote
Old 03-26-2007, 04:03 PM   #18
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Wheel studs for 1976 A/S
Originally Posted by Beginner
I ordered the following from Southwest Wheel:
P/N 25-053: 26 each: Stud 1/2-Fine Both Ends
P/N 30822: 26 each: Chrome Nut 1/2-20 Acorn Long
You can see them in my gallery.
Beginner
I have a 1976 31' A/S. I wonder if these studs 1/2 1/2 fine would work for the 1976. Thanks for any input.
Don
adonh is offline   Reply With Quote
Old 03-26-2007, 06:50 PM   #19
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by adonh
I have a 1976 31' A/S. I wonder if these studs 1/2 1/2 fine would work for the 1976....
1/2" fine is what you need to screw into the drums, 1/2" fine is what most trailer lug nuts are, but you should be able to find the exact thread you need if you are trying to match up to a set of nuts that you already have....note that it is probably not recommended by the manufacturers to use the same lug nuts on aluminum rims as you would on steel or chrome rims.
I have a set of 1/2" fine lug nuts for a stock steel rim if you need them.
Welcome to the Forums, Don - do you have any pics of your rig or any plans for a rebuild?
Dennis
WBCCI # 1113
AirForums #1737
Old 03-26-2007, 08:07 PM   #20
1984 31' Excella
Norfolk , Virginia
Images: 11
Stud Installation
The only concern I ran into is the fat part in the middle of the stud. I had to counter bore(drill a shallow hole large enough in diameter so that the fat part was below the surface of the brakd drum. That allowed the taper of the lug nut to screw all the way soen to the face of the drum as did the lug bolts.
I had a retired machinist tool and die maker do it for me to pass some pocket change his way.
Beginner
Old 03-27-2007, 07:15 AM   #21
87MH's Avatar
1978 31' Sovereign
Images: 292
More Info In This Thread
Good reading here on the Al/Steel lug Nut/Bolt question
http://www.airforums.com/forum...nger+sovereign
Dennis
WBCCI # 1113
AirForums #1737
Old 05-04-2007, 11:24 AM   #22
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
stids and nuts
Beginner,
Did the chrome nuts you mentioned have the correct countour against the aluminum rims?
bimpy is offline   Reply With Quote
Old 05-04-2007, 11:33 AM   #23
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Stud Farming
Studs are a benefit in that the wear and tear takes place
On the nut and bolt, both cheap parts,
Not the bolt and brake drum, one cheap (but not easy to find), one expensive.
Plus the guiding studs offer.
klattu is offline   Reply With Quote
Wheel Separation and broken lug nuts wheel interested Wheels, Hubs & Bearings 87 08-01-2006 11:19 PM
Lug bolts for amuminum wheels donhardman Wheels, Hubs & Bearings 7 05-22-2005 09:37 PM
lug bolt size airtim Axles 8 03-09-2005 10:55 PM
Wheel confusion Sneakinup Wheels, Hubs & Bearings 11 02-15-2004 10:22 PM
