Old 04-29-2016, 04:15 PM   #1
2016 26' Flying Cloud
Southlake , Texas
Why does Airstream do this?
I owned a German car repair shop for 40 years and nearly every time someone called with a recurring wheel balance problem, it was caused by the same thing. Aftermarket wheels! All car manufacturers that I am aware of use hub centric wheels What I mean by that is that the hole in the center of the wheel is a pretty snug fit on the hub. Most aftermarket wheels are somewhat generic and they may or may not be hub centric. The 4 or 5 lugs will not hold the wheel centered. First pothole and the wheel is knocked a wee bit off center and it vibrates. 6 lugs won't do much better.
To solve this problem, there are several companies that make hub rings to fit between the wheel and the hub, thus eliminating the sloppy fit.
The hubs on my '16 Flying Cloud are 102mm and the wheel center is 104mm (with the hub cap installed). Doesn't sound like much, but the next time you have the lug nuts off, move the wheel up and down. You will be amazed at the amount of movement. The wheel has to be all the way against the brake drum because the hub mating surface is only about 1/4".
I have spent an hour or so looking for hub rings of the proper size and have not found any. Has anyone addressed this issue, or even thought about it?
I know this is a trivial issue, but many have commented that there is an earthquake going on in the trailer when driving. Wheels that are not concentric with the hub will contribute small tremors to the quake.
Bgibbs is online now   Reply With Quote
Old 04-29-2016, 04:32 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Never noticed or heard of this being a valid problem. Airstream uses the same off the shelf parts and pieces as every other trailer and rv maker out there.
MICHAEL
Old 04-29-2016, 05:34 PM   #3
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I ran a euro auto repair shop for years too!
I'm not sure that the issue is so much that the wheels are not centered but rather that those drums are not balanced! I spun a set of them up on my Hunter Road Force balancer and what I found sickened me!
I balanced that set of drums and then spun the wheel/drum combo on the balancer and it was round enough and balanced when I was finished.
Next time I'll simply purchase centramatics as I no longer own the Hunter machine.
It was amazing how out of balance those drums were...
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 04-29-2016, 06:31 PM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
All my wheels are centered with the studs, they are not hub piloted, my dodge is the same as the airstream.....
Old 04-29-2016, 06:44 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I have ran aftermarket wheels on my vehicles for decades and never had a bearing issue...never heard of them causing problems.
CRH is offline   Reply With Quote
Old 04-29-2016, 08:38 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Doesn't the shoulder on the lug nuts align the wheel, how could it be off?
Doug and Cheryl
Old 04-29-2016, 08:56 PM   #7
Southlake , Texas
I stand by my earlier comments. From looking at some of the Dodge forums, it appears that Dodge trucks have a high incidence of studs breaking due to the lack of hub centric wheels. I don't care how well balanced a tire/wheel is, if it is not round as it rotates it will vibrate.
I found a place that will custom make a set of rings that will fit the AS and I have ordered a set.
Unlike your car and TV you are not riding in your trailer and cannot tell if it is vibrating or not.
Old 04-29-2016, 09:00 PM   #8
norsea's Avatar
2008 30' Classic
On the road since 2000 , norseaodyssey.com
Centramatic Wheel Balancers...
This is one of many reasons why I run Centramatic Wheel Balancers on all of my vehicles...
http://www.centramatic.com/
Given them a call. They are thoroughly familiar with all the Airstream models and know exactly what version of their product you will need.
Regards,
We are travelers with an attitude. We get to go anywhere, anytime, and have attitudes about what we see and hear.
"Travel is fatal to bigotry, prejudice and being narrow minded."
norsea is offline   Reply With Quote
Old 04-29-2016, 11:18 PM   #9
dkottum's Avatar
Well, you can learn something every day. Here's a sample of the much info that is available about it.
http://tires.about.com/od/understand...ric-wheels.htm
Centramatics won't help if the wheel is pushed off center, need rings.
Doug and Cheryl
Old 04-30-2016, 04:09 AM   #10
Bruce B's Avatar
The problem with adding rings to "lug centric" wheels is that there is no guarantee that the center of the hole is actually the center of the wheel!
Each style, lug centric and wheel centric, is designed to be centered in a different way. I've spent a lot of time chasing wheel centric centering problems due to corrosion or mis shaped parts!
My own airstream wheels centered perfectly on the drums when I checked them on the RoadForce balancer...that's what a RoadForce balancer does...it looks for eccentricity. It has the ability to measure .001" deflections in a rim or in the case of the way I set it up in the rim/drum assy.
As I mentioned earlier though, the balance of the drums was abysmal. Somewhere here I have videos of traveling inside our Airstream both before and after balancing the drums... The difference is amazing.
I would never go through the exercise of balancing the drums again...it was a pain in the but! Next time I change drums I'll add centramatics.
Bruce
Old 04-30-2016, 04:19 AM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The best fix for the unbalanced wheel drums could be the conversion to disc brakes.... and then add Centramatic wheel balancers along with properly balanced tires and wheels on a spin balancer.
There is almost a certainty that the brake drums today are made way off shore with nary a thought of balancing them before shipment let alone at the factory installing them or the parts store selling them....
Old 04-30-2016, 04:27 AM   #12
Bruce B's Avatar
Not only that but the stopping power of the drum brakes used in these Airstreams is terrible! Discs would at least be able to apply some brake force.
After reading somewhere here that the drums were unbalanced at the factory I called Dexter and asked if this was true. They confirmed that the drums were in fact not balanced. This is what prompted me to check mine.
Bruce
Old 04-30-2016, 06:58 AM   #13
dkottum's Avatar
Different conditions being discussed now. Non-concentric wheel/hub assemblies, unbalanced hubs, disc brake conversions as a cure, stopping ability of drum brakes , and which of these conditions Centramatic wheel balancers will cure.
I know little about any of it. Our wheels seem be rolling smoothly evidenced by nothing bouncing around in the Airstream during many, many miles, our drum brakes will lock up the wheels (it's more a question of extreme fade on long downhills, which hasn't happened), and I'd rather not buy add-on balancers, disc brakes, and concentric rings if we don't need them.
But I want to learn something so am listening.
Doug and Cheryl
Old 04-30-2016, 08:09 AM   #14
2010 27' FB Classic
N/A , Texas
If the wheels or tires were out of balance wouldn't there eventually be odd tire wear?
Zip Dee: Why, oh why, doesn't Airstream upgrade? robi General Repair Forum 66 05-01-2016 12:53 PM
Looking to downsize and simplify. Is Airstream a good option? Why? why not? jeremymm Full-Timing 23 12-05-2014 05:34 PM
Why does an Airstream tow better than its kin Tony S Towing, Tow Vehicles & Hitches 15 05-20-2010 08:52 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 07:15 PM
