Old 05-03-2016, 09:08 AM   #29
Maniacal Engineer
barts's Avatar
Menlo Park , California
Originally Posted by J. Morgan View Post
In twenty years there will be very very few thirty year old vehicles. The lifespan of modern vehicles will coincide with the lifespan of the wire insulation (which is not what it used to be) and availability of assorted electronic components.
Superat stultitia.
Do you have some evidence/studies for this?
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-03-2016, 09:22 AM   #30
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Of course not, Bart. It's clearly an opinion. So, now you're just trolling. 😉
Rocinante is our 2014 International Signature 27FB
Old 05-03-2016, 09:32 AM   #31
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Why does Airstream do this?
- Bart
I have observational skills.
After about 20 years the modern wiring insulation crumbles off of the wires especially in high heat areas.
The insulation that is used now is very durable in the short term, but under performs in the long term.
Once the wiring becomes generally bad, the cost of repair, and the difficulty in repair will be prohibitive.
Add to this that components used all over vehicles, (window switches, actuators, dash controls, etc) often utilize microprocessors, they will not be economical for the aftermarket to support.
While it is true that modern vehicles are in many ways superior, I do not think that this will translate into the years of viability that we have become accustomed to.
Even today, new vehicles that incur electronic gremlins can be difficult to resolve, this will get even worse as vehicles age.
Superat stultitia.
Old 05-03-2016, 01:09 PM   #32
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Interesting opinion.
I have a '96 Lincoln Mark VIII that will be voting in November. No issues with wiring or the insulation of same. While there have been some electronic component failures of some sensors and actuators none of the wire insulation that makes the connections has been a concern.
And the environment that my Mark operates in couldn't be much hotter.
Just my opinion, I own 9 vehicles with 4 of them made before 1972. The older vehicles are very simple to make repairs however the construction is far inferior to vehicles made in the last 20 years. Inferior in material, design and assembly. Maintenance is so much easier on the newer vehicles. Not that there are no issues because everything built has issues. For the most part the issues have a swifter and easier fix. (However usually more expensive)
>>>>>>>>>Action
Old 05-03-2016, 01:38 PM   #33
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The insulation will begin to crumble near the plugs and connectors first and then progresses.
Get back with me in ten years.
Superat stultitia.
Old 05-03-2016, 03:39 PM   #34
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Superat stultitia.
I had a 93 Mercedes 300e that had the main wiring harness replaced before I bought it in 2000. By the time I got rid of it in 2009 or 2010, the ancillary harnesses were falling apart. This because MB decided to go with a "green" insulation material and process.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-03-2016, 07:36 PM   #35
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Even if it turns out that wiring itself is not an issue, there will be a lot of components that will be replaceable "salvage only", which itself is going to be problematic.
Superat stultitia.
Zip Dee: Why, oh why, doesn't Airstream upgrade? robi General Repair Forum 66 05-01-2016 12:53 PM
Looking to downsize and simplify. Is Airstream a good option? Why? why not? jeremymm Full-Timing 23 12-05-2014 05:34 PM
Why does an Airstream tow better than its kin Tony S Towing, Tow Vehicles & Hitches 15 05-20-2010 08:52 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 07:15 PM
