Old 08-09-2013, 01:46 PM   #15
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Originally Posted by F450Harley View Post
http://www.airforums.com/forums/newr...eply&p=1231726
Check above post for whatever it worths.
I read this earlier. Thank you.
- evan
eheffa is offline   Reply With Quote
Old 08-26-2015, 03:31 PM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I may order the 1504 system.
What does the nicer 1506 display do that the 1504 display does not do?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-27-2015, 08:24 AM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Should be the same Dill #1900 display that has eight sockets.
Installation location needs to be carefully considered so it is not in direct sunlight. We had to use the included external magnetic mount antenna and put it on the rear Curt hitch. We had to lengthen the supplied coax cable with parts from Radio Shack.
In theory, I could have used just one display and switched it between the tow vehicles as the receiver plugs and tire senders could have had eight different letters of the alphabet. There would have been no spare capability unless I ordered ten or twelve different lettered senders and receiver ships.
Monday morning quarterbacking or hindsight is wonderful.
Old 08-27-2015, 09:56 AM   #18
m.hony's Avatar
2013 30' Classic
I thought about installing the Dill TPMS monitor in one of the 3 cupholders in the center console. I don't know why Toyota thinks everyone will have 2, 3, or 4 drinks each.
Uh-oh- our Radio Shack closed-
I think I have decided to forego the spare sensors- If you check the spare with a gauge at home before you start on your trip, it is not likely to go down just hanging around in the spare carrier-
The factory installed TPMS does on pickups does not include the spare- just the 4 that are on the ground-
I have a buddy with a fifth wheel who is trying to sell me on a different brand TPMS with monitors that screw to the valve stems.
May not get any TPMS or Centramatic balancers now. I'm spending quite a bit of money on this project. I've got ordered and on the way what I have to have to continue camping. I can get TPMS and Centramatic balancers later. As is, I am better off than I was with the 16" wheels, Load range E truck tires, and new chrome lug nuts- still a needed and beneficial upgrade-
TAC #MS-10
Airforums #70955
Old 09-05-2015, 06:29 AM   #19
m.hony's Avatar
2013 30' Classic
I need to find a better way to mount the Dill #1900 display using the external antenna and the hard wire kit.
I can't deal with this wire dangling.
Hard to believe there is no smooth flat surface anywhere in this truck but the glass.
I guess another option would be a bean bag GPS mount.
Name:	ImageUploadedByAirstream Forums1441456103.568706.jpg
TAC #MS-10
Airforums #70955
Old 09-05-2015, 06:33 AM   #20
m.hony's Avatar
2013 30' Classic
A little better, but still not ideal-
Name:	ImageUploadedByAirstream Forums1441456408.365582.jpg
TAC #MS-10
Airforums #70955
Old 09-07-2015, 11:47 AM   #21
switz's Avatar
2014 31' Classic
Images: 8
Here is where I mounted the Dill TPMS display above the Insight Engine monitor display and the DirecLink NE manual brake override control. The external antenna lead and power for the Dill display were brought up in the door post trim.
Name:	Dill & gages.jpg
Old 09-07-2015, 03:56 PM   #22
m.hony's Avatar
2013 30' Classic
I'm gonna try to mount it in the dash like a stereo or a/c controls.
I just don't like suction cup stalk mounts. I like everything to appear as if it came from the factory in the vehicle. One hindrance to installing it is the power coming into the bottom rather than into the back of the display. I wonder if the is such thing as a USB elbow or L plug.
TAC #MS-10
Airforums #70955
Old 09-07-2015, 05:25 PM   #23
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Agreed the Dill display is s dash hog.
I got a 90 degree antenna connector and it helps.
My power connection is on the bottom.
I don't use the glass suction cup mount, doing Velcro to a suitable spot.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-07-2015, 05:50 PM   #24
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Yes, there are USB mini "Ell" adapters and cables with "Ell" connectors.
A search on Amazon will turn up plenty.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 09-07-2015, 08:37 PM   #25
m.hony's Avatar
2013 30' Classic
The straight in antenna connection is not a problem if I mount it in dash and use the supplied external antenna. The power coming in at the bottom is a problem.
TAC #MS-10
Airforums #70955
Old 09-08-2015, 09:43 PM   #26
switz's Avatar
2014 31' Classic
Images: 8
The SenDel wheels need the 0.453" valve diameter Dill TPMS sender.
