Old 10-07-2006, 06:04 PM   #1
Mom scared by aluminum
dmaiden's Avatar
Phoenix , Arizona
wheels the same?
I just scored (or stupidly bought, depending on your outlook) a 53 Spartanette. It has the chevy 6-hole wheels. I am picking up my 63 Flying Cloud this week and am wondering if the wheels will be the same.
And yes, the divorce is pending.
Dave
dmaiden is offline   Reply With Quote
Old 10-09-2006, 03:29 AM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow Wheels
Hi Dave; Most standard automobile rims are not suited for an Airstream, althought they may fit. PO may have installed anything that fitted. Be sure that the rim capacity matches your application requirement. Tires as well have to be ST rated with proper sidewall requirement. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 10-09-2006, 06:52 AM   #3
dmaiden's Avatar
Phoenix , Arizona
Thanks Boatdoc
I picked up some white spoke wheels and c rated tires just to get the flying cloud home, but will definitely be upgrading as part of the restoration. Thanks
Dave
Old 10-09-2006, 03:14 PM   #4
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Most of your wheels have a weight capacity stamped inside them. Make certain they are the correct ones for your use. Many good and pretty ones out there to choose from just look twice before you buy.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 10-10-2006, 08:10 PM   #5
dmaiden's Avatar
Phoenix , Arizona
Got it
My wheels are rated for 2200 pounds each. and they DID FIT. Yay. Heading from LA to PHx on Friday. Cross your fingers.
Dave
Dave and Joanne
1963 Flying Cloud
2005 Silverado 4x4 3/4 Ton
Old 10-10-2006, 08:15 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Dave
2200 should be enough. Our current Airstream has wheels rated for 2600, and one of our Argosies had 1900 pound rated wheels from the factory (lighter trailer).
Airstream Wheels JAG Wheels, Hubs & Bearings 10 06-01-2006 08:54 PM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Airstream steel wheels davidz71 Wheels, Hubs & Bearings 0 05-21-2002 05:18 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
