Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 08-06-2009, 06:02 PM   #1
Profile:  1968 28' Ambassador
Livingston , Montana
Wheels for a "68 Ambassador
Hello,
I'm new to the forums and just purchased my 1st AS. It's a 1968 Ambassador, 28ft. Will be doing a restoration on it this winter and would like to know what aluminum wheels would work best for this trailer.
Mike
JokerDJD is offline   Reply With Quote
Old 08-06-2009, 07:53 PM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings Mike!
Originally Posted by JokerDJD View Post
Hello,
Mike
There really isn't a one-best answer to this selection as there are many alloy wheels available that meet the minimum specifications for Airstreams. The basic specifications are as follows:
15" X 6"
6 Lug
5.5" on Center
Offset = 0
4.25” Center Bore
2600 LB Capacity
Max PSI-65
Earlier this spring, I purchased a set of alloy wheels for my Overlander and I have been quite pleased with their quality and appearance.
The Wheel that I purchased is above, and I went through Trailer Tire and Wheel with great results -- delivery in about 72 hours following order.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 08-09-2009, 10:29 AM   #3
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
There are many wheel choices. You choice also has a load restriction. A passenger car type wheeel will not have the load capacity of 2600 #'s to do the job. Keep that in mind when choosing.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 50 10-11-2009 09:14 AM
change from 14" to 15" wheels?? happiestcamp Wheels 8 05-02-2007 11:57 AM
"new" '63 Ambassador repair questions campbell Member Introductions 7 04-14-2007 09:04 PM
Wheels and Tires for a 1960 28' Ambassador jeffcam Tires 6 12-16-2006 03:51 PM
1967 28' ambassador wheels/rims hazhoni Tires 2 09-15-2006 08:02 PM
