Old 05-05-2008, 11:53 PM   #1
Wheels for a 1963 Overlander?
I just searched the Wheels forum and didn't see this specific question addressed, so I hope I'm not being redundant. I'm hoping somone can tell me the proper wheel size and tire size for a '63 Overlander?
Similar models in nearby vintages seem to call for 15" , 6 lug, 5.5" bolt pattern, and zero offset. Is that correct? Since there are 4 wheels and the dry weight is probably somewhere around 4200 - 4500 lbs, what would be the appropriate weight rating for each individual wheel?
And then for tires-- without debating BRANDS , what is the appropriate tire size for the '63 Overlander, and again what weight rating would be appropriate since there are 4 tires on the tandem axles?
Thanks in advance!
Old 05-06-2008, 12:05 AM   #2
Thanks in advance!
Wheel size = 15 x 6 on 5.5 inch circle.
Wheel rating = 2600 pounds minimum
Trailers turning create considerable side pressure. Cars do not.
Tires = ST 225 / 75 R 15 Load range C for a 26 foot trailer is good, but load range D is better, but only if you start off with new wheels.
Once a wheel has been in service for an extended period of time, you cannot safely increase the load limit without the risk of the wheel splitting.
Old 05-06-2008, 12:15 AM   #3
Thank you so much Andy, much appreciated!
A New Challenge-1963 Overlander rehab project overlander63 1960 - 1964 Overlander 896 04-07-2017 05:48 PM
1963 Overlander Why bearings can NOT be repacked? Zstream Axles 6 04-30-2008 01:23 PM
Axles installed in 1963 on Overlander? Zstream Axles 3 04-30-2008 10:30 AM
1963 Overlander Electrical Adaptor / Brakes erikjware Brakes & Brake Controllers 1 02-22-2008 04:43 PM
Wheels for 1961 Overlander David Hall Wheels, Hubs & Bearings 19 01-29-2004 08:24 AM
