Old 05-04-2019, 12:42 PM   #1
1965 17' Caravel
Wells River , Vermont
wheels for 65 Caravel
Having put a new axle, rims, tires on 65 Caravel, we experienced a ruined tire within 7,000 miles as shown in photo. The other tire is fine. What could be the cause? It doesn't appear to have been a problem with the tires.
Meanwhile we tried to put on the spare and cannot get the tire up into place--there isn't enough room to get it in and lined up with the hub. These are 15" offset rims. Do we need to go to a 14" rim? The new tires/rims were installed by someone else, and one has to wonder how he got them in place. All we can figure out is the tires weren't inflated at the time.
Any ideas, suggestions, etc, most welcome.
Ann
Newbury is offline   Reply With Quote
Old 05-04-2019, 02:20 PM   #2
1966 22' Safari
Fredericksburg , Texas
According to the 1965 brochure, the tires were 6.70x15 6-ply. Are the center of the hubs both equal distance from the hitch ball?
Bubba L is offline   Reply With Quote
Old 05-04-2019, 02:44 PM   #3
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Ann
We recently replaced the wheels on our 68 Caravel. I ran new Goodyear Endurance ST205/75 R15 on the original wheels for the 600 miles from where we bought the trailer. I realized that the original wheels were not rated for high pressure tires and that we would most likely run the Endurances at a higher pressure than the original wheel spec.
I purchased a new set of 15x6 5 bolt 4.4, 75 psi wheels from VTS. The tires are just a slight bit wider on the new wheels, although the new wheels are the same spec as the originals, or so I thought. In reality they are 1/8 to 3/16 inch wider just enough to cause wheel well edge clearance issues on the curb side when mounting and un-installing. So we have to deflate the tire on the curb side in order mount the wheel. I'm looking into creating more clearance by possibly removing some material from the inside of the wheel well.
We just recently discovered the issue so hopefully I can post news of a solution shortly.
SilverWind is offline   Reply With Quote
Old 05-04-2019, 08:14 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Or the axles were in better shape.
How old are those tires?
>>>>>>>>Action
Old 05-05-2019, 07:07 AM   #5
1965 17' Caravel
The tires, wheels and new axle were put on in Jan 2016. We drove from VT to Ajo, AZ, not too far from Phoenix (!) and back. She went into storage over winter. Just discovered the tire and are SO grateful that we didn't have a disaster on the road. The manual we have on page 17-2 says: 7:00x15 travel trailer tires (Carael has 7:50X14 tubeless).
We dug a hole in the ground and took air out of the tire and still couldn't. But you're right--more clearance is needed. The answer to that part of the problem looks like new rims/tires in size 14.
Still need to figure out why one tire went bald and other is nearly perfect. Need to check re Bubba's question. Old tires didn't have this problem, so we are thinking it's tied to the new axle. Will be checking with our restoration guru on Mon morning.....
thanks
Old 05-16-2019, 06:24 AM   #6
1965 17' Caravel
The probable answer
It looks like the cause of the worn tire is probably that the axle got bent. Seemingly a pot hole can do it, so the axle must be fairly delicate. Our repair choices are a new axle or possibly a repair to the old one. We are going to consult a specialist in Barre first about a repair. He was highly recommended by an ardent enthusiast (not an Airstream person), so we'll see how that goes.
caravel
Wheels-up or two wheels down dolly towing? chriscraw General Motorhome Topics 17 01-30-2017 05:59 PM
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
