Old 10-30-2003, 07:52 PM   #1
Wheels
Hi All. Need some help with my trailer wheels. What year did Airstream go to tubeless tires on there steel rims. I have a 1970 and would like to go to tubeless tires. with steel rims . Has anyone tried tubeless tires on these wheels ?If I use a truck type valve stem with a nut & sealing washers would a tire seal on this rim? Any ideas opinions, thoughts will be helpful Thanks in Advance
poorboycjs is offline   Reply With Quote
Old 10-30-2003, 07:57 PM   #2
I went to tubeless on my 1972. Only requirement was putting bead seal on standard tubeless valve stems.
Good Luck
George Jr.
George Jr. is offline   Reply With Quote
Old 10-31-2003, 11:13 AM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
If you have the original Airstream wheels on your trailer, then tubeless tires are not a problem.
It is imprtant that here is no rust on the bead area, and that the valve stems you are using are good for the 65lb pressure that is possible in load range D tires.
If your weels are rusty, and you want to replace them, PM me, i have a set available.
Uwe
www.area63productions.com
Tires & Wheels for a '66 Overlander 66Overlander Tires 16 05-28-2004 11:20 PM
16" wheels for my A/S Chipster Our Community 2 03-18-2004 01:11 AM
Wheels for 1961 Overlander David Hall Wheels, Hubs & Bearings 19 01-29-2004 07:24 AM
Chroming the wheels thenewkid64 Airstream Motorhome Forums 10 09-11-2003 04:22 PM
alloy wheels T&R Wheels, Hubs & Bearings 3 05-19-2003 06:52 PM
