Old 04-24-2015, 07:06 AM   #15
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
I'm contemplating upgrading to 16 inch wheels as well. Believe it or not, I had a steel wheel start leaking at the bead transition on our last trip.
Does anyone have a diameter measurement of the new 16 inch Sendels with the Michelin LTX M/S LT 225/75 R 16 Load Range E installed and inflated? I just want to do a comparison of the full diameters of the old wheel and tires I have, to what I'm contemplating. I'm sure there's a way to calculate it and figure it out, but nothing like an actual measurement.
By the way, I have several old 15X6 steel wheels with 7.00-15 tires (a couple of different brands). The old wheel and tire full diameters run between 28 and 29 inches.
Thanks in advance,
Roy
64airstream is offline   Reply With Quote
Old 04-24-2015, 07:13 AM   #16
dznf0g's Avatar
Oswego , Illinois
Roy,
29.4" , but I believe you have to get the M/S2 now. I don't see the 225s on Tire Rack in the M/S anymore.
-Rich-
Old 04-24-2015, 09:22 AM   #17
1964 22' Safari
1968 26' Overlander
Thanks, Rich. I appreciate the prompt response. M/S 2 sounds good.
Roy
Old 06-25-2017, 09:37 PM   #18
2013 25' International
Boise , Idaho
I've got the same issue
I need new rubber for my 2013 25' Serenity but am in the same situation as the OP. Curbside rear wheel is 1" to the trim - this is measured from tire surface to trim surface and represents the literal gap, not a visual one.
Putting on 16" wheels/tires would reduce that gap to around .5" - which strikes me as too close for comfort. Is it, and if so, what to do?
Is trimming the wheel well something a body shop would make quick work of? Is it something I can do - given very little experience of this sort?
Love to hear, thanks.
-Adam
afk314 is offline   Reply With Quote
Old 06-30-2017, 08:48 PM   #19
2007 27' International CCD FB
San Diego , California
I almost went to 16" wheels, but found that I could readily get tires with sufficient load ratings in a slightly larger 235/75/15 tire. These are .6" taller than the stock 225/75/15s and fit great on my 27FB.
No point letting a nice stock 15" aluminum wheel go to waste. It's probably a gentler ride for the AS also with more tire sidewall.
pteck is offline   Reply With Quote
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 85 11-28-2017 07:58 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
