Originally Posted by Bigdaddy_2
...Looking for thoughts about the studs and whether I should be replacing them with same as originals...
hi big'
had the same need to replace studs a few months ago...
and also purchased the napa replacements...
while the threaded shaft length and cap diameter/thickness aren't exact matches...
the GRADE and shaft DIAMETER and KNURL diameter and THREADING are all the same as oem...
i was assured by a/s, napa, the service shop, AND kodiac...
that the replacement stud was equal to oem, as long as the knurl and grade thread/diameter were the same.
because the endcap/lip aren't exact matches, they had to settle in some and did need re-torquing...
but are now working FINE.
eventually i'll replace ALL 36 of the oem studs with these napa replacements...
because the threaded areas DO stretch and weaken the studs over time.
it is possible a dealer or the factory could get oems but it's a pia for them and not worth the price/markup/effort...
cheers
2air'
