Old 02-28-2016, 05:03 PM   #1
1998 30' Excella 1000
Livingston , Texas
Wheel Sizing/Center Bore Tolerance
I'm now shopping for wheels to upgrade to 16 inch tires. While those Sendels sure look real sharp, I'm considering trying to maintain my Classics traditional look with steel spoke wheels. While I have not made up my mind yet, the only wheels that I can find that fit and are silver painted (versus white), have a center bore of 4.28". Three hundreds of an inch bigger than the OEM wheels. I would not think that would be an issue. Any thoughts out there?
Siegmann is offline   Reply With Quote
Old 02-28-2016, 05:34 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Steel will rust, steel are heavier, alumium is lighter, aluminum does not rust, tires will run cooler with alunium, you better see if a magnet sticks to your present wheels, I'll bet they are alumium....
tjdonahoe is online now   Reply With Quote
Old 02-28-2016, 05:52 PM   #3
Livingston , Texas
My original wheels are steel. Only very minor superficial rust. Must have been a good factory paint job. Someone once posted the weight difference, and it was surprisingly small. I think the aluminum must be much beefier to equal the strength of the steel. Don't know about the tires running cooler. I guess in theory; the aluminum is a better conductor of heat. But there is so little contact area... anyone else have thoughts on this?
Old 02-28-2016, 06:25 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I dont think that .03 is going to make much difference, that is like a coat of paint.
Steel wheels have been on my trailer for for about 44 years.... I think they came with the trailer new.
I painted them a couple years back, but they were not overly rusty or heavy.
When they need it, they can be repainted.
Beyond this, I don't think my wheels are hub piloted anyway.
Talis gentium ceciderunt.
Old 02-28-2016, 06:29 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I don't know, I kind like not being trendy.
Name:	ImageUploadedByAirstream Forums1456709362.343535.jpg
Old 02-28-2016, 09:29 PM   #6
Livingston , Texas
Yup, I like my original steel wheels too. But this forum has got me nervous enough about ST tires that I want to upgrade to 16" LT tires.
Thanks for the feedback.
Old 02-28-2016, 10:36 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I ran a set of ST tires on my trailer for a while. I did not like how quickly they wore out so I replaced them with a set of 15" LT tires with 2040 lb weight ratings.
They wear much better.
Old 02-29-2016, 05:33 AM   #8
Gainesville , Florida
Correct size 16 inch steel wheels can be purchased from etrailer for about 70 dollars a piece.
Old 02-29-2016, 07:30 AM   #9
Livingston , Texas
But last time I checked they were only available in white, for a 4.25" center bore. I could paint them silver, but I think factory paint would be far more durable. To get them from the factory in silver, would mean accepting the 4.28" center bore.
Old 02-29-2016, 10:40 AM   #10
1977 31' Sovereign
Lynnwood , Washington
0.03" is close enough for occasional farm work (or maybe for use as a spare). But for extended highway travel, you want center holes on your wheels that fit snugly, as intended.
Remember, it's the all-important center hole that supports the weight of your trailer, not the lug nuts.
Tom
TomKirk is offline   Reply With Quote
Old 02-29-2016, 10:48 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Not all wheels are hub piloted. In fact a great many wheels are not, including my stock Airstream wheels.
Old 02-29-2016, 10:58 AM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Beyond this, the stock hub piloted wheels I took a quick sample of just now allowed a .030 feeler gauge to easily pass into the gap between the hub and wheel. (2 for 2)
Name:	ImageUploadedByAirstream Forums1456768700.991995.jpg
Old 02-29-2016, 11:05 AM   #13
Hans Grim's Avatar
1993 29' Excella
Brighton , Ontario
[QUOTE=J. Morgan;1755677]I don't know, I kind like not being trendy.
That is a great look IMO.
Hans Grim
1993 29' Excella
2011 GMC Sierra 2500 HD 6.0L
Hensley Arrow
Hans Grim is offline   Reply With Quote
Old 02-29-2016, 12:27 PM   #14
1996 25' Excella
Tillsonburg , Ontario
Lug nuts hold the wheel centered IMO. Air Stream SS hub caps are loose by at least 30 thou. and the wheel holds them in place after the nuts are tightened. Some of my automotive wheels need to be pounded on and off ( usually the front hub) and my truck wheels slip on an off easily so the lug nuts must be doing the whole job. That's why they are conical
JCW
JCWDCW is offline   Reply With Quote
Bolt/wheel pattern sizing - 62 globetrotter Stupidnoob Wheels, Hubs & Bearings 1 02-07-2015 10:27 AM
Bore scope recommendations bkahler General Motorhome Topics 24 11-15-2012 07:01 AM
structural deflection how much is within tolerance 64globetrot General Repair Forum 1 05-20-2009 07:11 PM
Community Policies - Zero Tolerance PeterH-Airstreamer Our Community 0 01-01-2003 07:05 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
