Old 03-03-2016, 10:25 AM   #29
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by CapriRacer View Post
If you have a choice, no.
Please be aware that the needed for hub piloting is much more extreme for vehicles with passengers than with trailers and no passengers.
Also be aware that many aftermarket wheels can be fitted with hub rings that serve the purpose of hub piloting the wheel.
Understand the logic, just question the reality. Having said that, everything I read says soft ride with no vibration is best for the coach. That would make having a wheel off center a terrible idea, passenger vehicle or not.
So, IS AN AIRSTREAM AXLE HUB CENTRIC? Really wish I had looked closer when mounting the 15s. Since the hub cap moved, I do not believe they are, but ......?? Pat
Old 03-03-2016, 05:36 PM   #30
Central , Mississippi
Wheel Sizing/Center Bore Tolerance
All of the airstreams I've messed with or replaced the axles on were lug centric. The hubs were too small of a diameter to center a rim.
You can test this by jacking and removing the rim. With the lug nuts removed the rim flops around on the hub and the studs won't center on the holes until the first nut is run up.
On edit. The rims with the pretty little center cap that slides in from the rear might want to be hub centric, but loose the cap and it's now 100% lug centric.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Bolt/wheel pattern sizing - 62 globetrotter Stupidnoob Wheels, Hubs & Bearings 1 02-07-2015 10:27 AM
Bore scope recommendations bkahler General Motorhome Topics 24 11-15-2012 07:01 AM
structural deflection how much is within tolerance 64globetrot General Repair Forum 1 05-20-2009 07:11 PM
Community Policies - Zero Tolerance PeterH-Airstreamer Our Community 0 01-01-2003 07:05 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
