Old 02-29-2016, 08:32 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
As a rule, (there are exceptions), lug nuts that have a taper hold on stud piloted wheels, and lug nuts that are flat at the point of wheel engagement hold on hub piloted wheels.
Talis gentium ceciderunt.
Old 02-29-2016, 08:46 PM   #16
1998 30' Excella 1000
Livingston , Texas
I was getting ready to ask about that. Thanks for posting the answer.
Siegmann is offline   Reply With Quote
Old 03-01-2016, 07:13 AM   #17
CapriRacer
CapriRacer's Avatar
I'm in the , US
My experience says that:
1) Cars and light trucks use hub piloting to center the wheels. I know of no exceptions. (OK, I'll grant that aftermarket wheels aren't always hub piloted, but the car manufacturers ALL do hub piloting.)
2) There are enough cars and trucks using tapered lug nuts AND hub piloting that I don't think anyone can make a rule about the lugs vs wheel centering.
3) The reason cars and trucks use hub piloting is that stud piloting isn't as good - too many things to go wrong with stud piloting.
CapriRacer is offline   Reply With Quote
Old 03-01-2016, 10:05 AM   #18
Gainesville , Florida
So are trailer wheels all the same type. .? If the spacing of the lugs is the same and the offset is correct? Same number of lugs. 5.5 inch 6 lugs zero offset.
xrvr is online now   Reply With Quote
Old 03-01-2016, 10:54 AM   #19
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Does this mean that you are against aftermarket replacement wheels that are not hub piloted?
Old 03-01-2016, 11:18 AM   #20
Livingston , Texas
So now I am confused. Does anyone know if the Airstream OEM wheels are lug piloted on the 1990's and up rigs that have tapered lug nuts?
Old 03-01-2016, 11:42 AM   #21
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If the lug holes in the wheels are tapered, that is funnel shaped, and the lug nuts are tapered to match, the wheels are lug piloted. If the lug holes are flat and the lug nuts are also flat, the wheels are most likely are center hole piloted. Some aluminum wheels have the lug holes drilled precisely, and use lug bolts which are flat against the wheel, but still the lugs center the wheels. The after market aluminum wheels on our '83 Excella have 4.25 center holes, much larger than the hub, and are centered by the lug bolts. The bolts go through the holes in the wheel. The lug bolts are tapered on the end, so that they may be used to mount the spare which is a lug piloted steel wheel.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 03-01-2016, 12:09 PM   #22
Livingston , Texas
All the trailer wheel specs I've run across have described the opening diameter as "center bore". This outfit interestingly called it "center hole" with a separate diameter for the "cap". Should be a perfect replacement for the orlginal Airstream wheels. Has anyone ever ordered anything from this supplier?
http://recstuff.com/trailer-tires-wh...tar/#viewparts
Old 03-01-2016, 04:01 PM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
My 72 wheels are positively stud piloted.
See for your own self!
Name:	ImageUploadedByAirstream Forums1456869702.670119.jpg
Old 03-01-2016, 05:34 PM   #24
1976 31' Sovereign
Oswego , Illinois
Smile
I pur. 4 15 inch aluminum wheels several years ago form this supplier. The brand was hi spec, price was best I could find. I can not find any fault with this bus. Would pur. from them again if needed any thing.
Old 03-02-2016, 07:24 AM   #25
CapriRacer
CapriRacer's Avatar
I'm in the , US
Sort of, but what I am actually saying is I recognize that lug piloted aftermarket wh
Originally Posted by Jim Foster View Post
If the lug holes in the wheels are tapered, that is funnel shaped, and the lug nuts are tapered to match, the wheels are lug piloted. If the lug holes are flat and the lug nuts are also flat, the wheels are most likely are center hole piloted. .........
As I stated above, I know of many vehicles where the wheels are hub piloted, but have tapered lug nuts.
So, NO!!! Tapered lugs does NOTequal lug piloted.
Old 03-02-2016, 01:53 PM   #26
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Would you recommend that non hub piloted aftermarket wheels not be used in place of hub piloted stockers?
Old 03-03-2016, 07:36 AM   #27
CapriRacer
CapriRacer's Avatar
I'm in the , US
If you have a choice, no.
Please be aware that the needed for hub piloting is much more extreme for vehicles with passengers than with trailers and no passengers.
Also be aware that many aftermarket wheels can be fitted with hub rings that serve the purpose of hub piloting the wheel.
Old 03-03-2016, 08:05 AM   #28
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yea, come to think of it the aftermarket wheels that I had put on my truck by Discount Tire have plastic hub pilot inserts.
It doesn't seem like these inserts do a lot of work other than holding the rim in place prior to tightening.
Bolt/wheel pattern sizing - 62 globetrotter Stupidnoob Wheels, Hubs & Bearings 1 02-07-2015 11:27 AM
Bore scope recommendations bkahler General Motorhome Topics 24 11-15-2012 08:01 AM
structural deflection how much is within tolerance 64globetrot General Repair Forum 1 05-20-2009 08:11 PM
Community Policies - Zero Tolerance PeterH-Airstreamer Our Community 0 01-01-2003 08:05 PM
Tire sizing question casarodante Tires 5 07-02-2002 11:19 PM
