Old 07-09-2014, 04:12 PM   #1
redondo beach , California
Exclamation Wheel seals for a Silver Streak
I am looking for wheel seals a silver streak clipper Trostel 3---156-6E can anyone help? John
PLVMB is offline   Reply With Quote
Old 07-09-2014, 04:21 PM   #2
That seal is also National # 290944.
They are felt 10 inch drum seals.
No one makes them any more.
The dimensions are:
Thickness 3/8 inch
Outside diameter 3.002 inches
The shaft diameter 1.875 inches
Hope this helps you.
Old 07-09-2014, 04:45 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Just go down to your local bearing supply store and have them match them up with something modern. You will need the spindle outside dimension at the sealing surface and the hub inside diameter at the seal seat.
Rare Silver Streak Motorhome, Like Airstream All Silver eBay Watch Airstreams on eBay 0 07-29-2011 06:04 PM
Needing 1965 Silver Streak Wheel/Tire Info BigJim General Repair Forum 1 01-26-2011 08:34 PM
Wheel pattern, 53 Silver Streak Clipper weaselRus Wheels, Hubs & Bearings 7 12-14-2009 07:55 PM
grease seals for wheel spindles BigAl Axles 8 04-17-2005 01:34 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
