Old 06-04-2007, 10:54 AM   #1
1973 31' Sovereign
dallas , Texas
Wheel questions
So I'm going to pick up this airstream trailor and it needs tires, can someone tell me what tires I need to run and what the bolt pattern is ? 6 on 5 1/2? and I was told this was a land yaught after looking around on the site I don't think thats what its called, it's a 73 thanks steve
Grandmaster is offline   Reply With Quote
Old 06-04-2007, 11:39 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You need 6x15 - 6 bolt on 5 1/2 zero offset. Got mine at Hubcap Annies if you have one in your area. They were Carlisle brand and have a 2650 lb. rating per wheel. White spoke - which I painted black.
Old 06-05-2007, 03:36 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Grandmaster,
You stated you want tires and then asked for wheel data. Ganglin gave you some of each. However I am going to ask that you clarify your q. Looking for tire data or wheel data or both?
BTW,
ON a slightly unrelated data.
Land Yacht is an option package or a trim level for Airstream
You have a;
Caravel
Globetrotter
Safari
Tradewind
Overlander
Ambassador
Sovereign
These model names corraspond to the length of the trailer. The above list is arranged from short on the top to long on the bottom.
>>>>>>>>>>>>>>>>>Action
Old 06-05-2007, 04:20 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Actually I only addressed the wheel issue. Only been around here since last July but learned quickly to avoid the tire issue - so I read what everyone else had to say - did some outside research and made my best decision on that topic.
Old 06-05-2007, 05:49 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Source?
I noted the Samba.com picture ref. I hope your not towing with a VW.
Those are 6x5 1/2 wheels. I still promote radials (because thats what Airstream says) instaead of bias. Be careful of the width size...its a close fit to the side wall. I like Tow Master.
Old 06-05-2007, 06:27 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Looks like an Overlander or Ambassador, probably an Overlander. Tire size would be ST225/75R15D, or 7.00R15LT, also load range D.
Old 06-06-2007, 09:29 AM   #7
From your photo's, it would appear that your axles are "shot."
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
The Junkyard Wheel Story Inland RV Center, In Wheels, Hubs & Bearings 1 04-10-2002 06:04 PM
