Old 05-20-2016, 02:11 PM   #1
Randakk's Avatar
2015 23' FB Flying Cloud
Pinehurst , North Carolina
Wheel Lug torque Spec?
New 15" Sendel wheels and Michelin tires arrive next week for our 2015 23FB.
Question: I assume the OEM lug nut spec of 110 ft./lbs of torque still applies.
Am I correct?
Thanks.
Randall Washington (Randakk)
Pinehurst, NC
2015 Flying Cloud 23FB
2015 Chevrolet Silverado 1500 WT 4WD
www.randakks.com
Randakk is offline   Reply With Quote
Old 05-20-2016, 02:19 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My manual says 110 to 120. I set to 115.
MICHAEL
Old 05-20-2016, 06:03 PM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
On my '15 FC, the Manuel speaks extensively on the importance of correctly torquing your wheels, and checking them at 10, 25, and 100 miles. But nowhere does it say what the torque values should be.
So I emailed Sendel, and asked. They said there should be a sticker on the trailer with the torque values, but if there is I can't find it. They also said industry standards are from 90-110 for their 15 inch wheels.
So I emailed customer service at Jackson Center, and got a reply from Craig Weir, who stated that the torque values for my wheels (Sendel T02 15) were from 110-120.
Mike
Caffeinated is offline   Reply With Quote
Old 05-21-2016, 06:10 AM   #4
Randakk's Avatar
Thanks.
Torque specs for 2015 Flying Cloud models are published here:
https://www.airstream.com/wp-content...Cloud_2015.pdf
That's where I retrieved the 110 ft./lb MAX torque value for aluminum wheels.
(Page 4-4)
Pinehurst, NC
www.randakks.com
Old 05-21-2016, 06:25 AM   #5
Portland , Oregon
Originally Posted by Randakk View Post
Thanks.
(Page 4-4)
Oh my, what a dolt I am. I was looking in the wrong place in my owners manual and could not find the values. It is in section 4. Thx Randakk.
Mike
Old 05-21-2016, 07:43 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have always used 115 ft. lbs. on my 16" Sendel T03's. I mark it above the wheel wells as a reminder.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 05-21-2016, 07:59 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Visiting Jackson Center Service Center last month we had our 16" Sendel wheels/Michelin tires rotated, brakes and bearings checked. I asked the tech what torque they used. 110 ft lbs for 15" aluminum wheels/tires, 120 ft lbs for 16" aluminum wheels. So that's what we use. They also put a sticker on the entrance door to recheck torque at specific mileages after wheel service, I don't remember the exact mileage.
Doug and Cheryl
Old 05-21-2016, 10:22 AM   #8
jackson center , Ohio
Am I correct?
Thanks.
Wheel torque for my 2014 Flying Cloud is 115#
Schu is offline   Reply With Quote
Old 05-21-2016, 10:57 AM   #9
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Wheel torque
I have 16" wheels. Just had tires rotated at JC this past Tuesday and they torqued at 130. That's the value also on the sticker they placed on entry door.
DeltaRon is offline   Reply With Quote
Old 05-21-2016, 11:22 AM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My 2013 31 classic says 110 lbs air, use it for the 16" also....
Old 05-21-2016, 11:24 AM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I go with 125 ft/lb on my 16" because JC told me the torque was 125-130.
They told me this in 2011.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 05-21-2016, 12:51 PM   #12
MarkFinATX's Avatar
2016 28' Pendleton
Austin & Santa Fe , TX & NM
So, the manual for our 2016 Pendleton states 110 ft./lbs. with 16" Sendel alloy wheels, and Michelin LT 225/75 R16's. I've been running the tires at 80 psi. Any suggestions for tire pressure?
Don't look back, you're not headed there anyway
MarkFinATX is offline   Reply With Quote
Old 05-21-2016, 01:18 PM   #13
AWCHIEF's Avatar
Images: 33
What does Michelin and Airstream recommend? There should be a sticker on the side of the trailer with recommended tire pressures.
MICHAEL
Old 05-21-2016, 01:20 PM   #14
PKI
PKI's Avatar
Walnut Creek , California
All quite interesting - The studs and nuts are all the same, correct? Seems odd that one stud would be torqued at one level and another at a higher level. The wheel material is same, surface area is same, and stud strength is same, only the load and force that might be applied is variable. Interesting that a 1/2-20 stud would be torqued to multiple different levels. Is the thickness and length of stud different between 14, 15 and 16 inch wheels or does the engagement length change when moving from the 5-6 hole wheel? Again, it is what it is. Just surprising that there is a difference. My education awaits your informed input. Pat
PKI is online now   Reply With Quote
Torque spec Aviator Axles 0 12-11-2010 05:49 AM
lug bolt torque dosstx Wheels, Hubs & Bearings 7 03-15-2009 12:01 AM
torque spec Daddy4Bob Mechanics Corner - Engines, Transmission & More... 8 02-18-2007 03:30 PM
Lug Nut Torque alan Wheels, Hubs & Bearings 46 11-27-2006 09:32 PM
Correct Torque for wheel lug nuts? Cracker Wheels, Hubs & Bearings 2 05-30-2004 09:24 AM
