Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 11-05-2003, 11:37 AM   #1
Cracker
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
Wheel and Hub Balancing plus Aluminum Wheels
In an earlier discussion about the need to balance the tires, wheels, and hubs as a unit, it was pointed out that the equipment for so doing is not commonly available. One of the participants volunteered to try and prepare a list of dealers across the U.S. who have this equipment. Was this ever accomplished? Can anyone else offer an alternative? Additionally, what is the caution to be observed with respect to re-mounting the cast aluminum wheels. Apparently they can be easily damaged if it's not done correctly?
Cracker
Cracker is offline   Reply With Quote
Old 11-05-2003, 03:19 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Cracker,
Aluminum wheels don't damage that easily. I always make sure to torque the wheels to 100ft/lbs. Also, clean the area where the wheel touches the hub, to make sure the wheel is flat against the hub. Corrosion and dirt can accumulate, causing uneven contact between the hub and wheel.
Depending on the design, alloys usually are much lighter than steel wheels, and therefore lessen the balance problem to a certain extend.
I can not help you with your other questions.
Uwe
Hubs (balancing) Sue&Von Wheels 14 07-31-2007 10:28 PM
Wheel hub leaking grease? rluhr Axles 13 01-19-2004 07:33 PM
wheel hub cover for 1960 Overlander Paul Schaefer Parts Archive 2 09-11-2003 06:45 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
