Old 04-07-2011, 04:14 PM   #1
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Wheel bearings- use Permatex??
I'm getting ready to repack my wheel bearings and I decided to read the Dexter manual that came with my Safari to confirm the grease specs. It mentions using Permatex sealant when installing the grease seals (on the metal outside where it sits in the hub).
I've never heard of that and think that nobody probably does it - but do you???
Old 04-07-2011, 04:17 PM   #2
dznf0g's Avatar
Oswego , Illinois
Never heard of any recommendation for any hub I've ever packed. I suppose it could reduce the traces of grease that tends weep out between the seal and hub, but I don't think it is worth the effort.
Old 04-07-2011, 04:28 PM   #3
1994 30' Excella
Mississauga , Ontario
probably makes it difficult to remove next time.
Al
Al and Jean
TAC ON-3
Old 04-07-2011, 04:48 PM   #4
tpi
Trabuco Canyon , California
i've never used Permetex, but maybe if exposed to a lot of water, like boat trailer, it would be beneficial.
tpi is offline   Reply With Quote
Old 04-07-2011, 05:51 PM   #5
2006 30' Classic
Milton , Florida
Contact Dexter
Why not send Dexter an email and ask for the reason behind the recommendation?
Dexter has been very good about answering my inquires.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 04-07-2011, 06:08 PM   #6
Wayne&Sam's Avatar
Images: 21
Thanks for the replies.
Old 04-07-2011, 10:49 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, several decades ago, the use of glues on seals was eliminated because they started making seals with a type of paint that did the job for you. If your wheel bearing seals are bare metal, then use some type of sealant on them. The seals in this picture do not need any glue or sealer on them.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-08-2011, 04:05 AM   #8
Wayne&Sam's Avatar
Images: 21
Ah, hence the blue color of the bearing case. I guess they put that in the manual incase you buy cheapo bearings. Thanks.
Old 04-08-2011, 04:46 AM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I started doing that after finding a seal that had either worked out of the hub or popped loose as I pulled the drum.. Certainly no harm in doing it. There would not be any relation between the quality of the bearings and retaining the seal
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-08-2011, 05:00 AM   #10
Wayne&Sam's Avatar
Images: 21
I meant that a cheaper seal may not have the sealant already on it.
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Seals For Wheel Bearings ~ 1958 Pacer Ariz-Pacer Wheels, Hubs & Bearings 9 03-22-2011 10:50 PM
wheel for 67 eubank Wheels, Hubs & Bearings 5 03-06-2011 03:39 PM
