Old 09-18-2013, 07:45 AM   #1
slk
Elk River , Minnesota
Wheel Bearings: max mileage?
How often or how many miles should be put on before you need to pack your wheel berrings. I have a 96 Excella. Packed them about 3,500 miles ago.
Steve
slk is offline   Reply With Quote
Old 09-18-2013, 08:02 AM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Steve,
We have ours repacked each Spring. I, too, will be interested in the responses from the veterans and pros here.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-18-2013, 08:34 AM   #3
slk
I am glad I decided to pack them. I have one side off right now and have found that the bottom return spring on each wheel I have off is broken. I called Airstream and they gave me the Dexter part number for them, as I could not wait for them to come to my dealer. We are going to Canada this Saturday. So NAPA has them, and they are only $1.49 each. I bought 4 anticipating the other side to be broken as well. I suppose an inspection once a year would be a good thing if you use it on the road.
Steve
Old 09-18-2013, 08:44 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Just what I do....
.....inspect brakes, wheel bearing, (incl end play) every year. Re-pack at 10k.
Do the preventative maintenance, that should help you determine when bearing service/replacement is needed.
These are OEM bearings...
ID:	195921   Click image for larger version
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-18-2013, 09:26 AM   #5
Steve
Bearings should be repacked and the grease seals replaced every 10,000 miles, or once a year.
Repack Wheel Bearings in Cincinnati, OH jhohe Wheels, Hubs & Bearings 37 06-08-2013 06:17 PM
Sealed Wheel Bearings greatlakes Wheels, Hubs & Bearings 7 12-05-2011 06:50 AM
Red Max Pro Taxman Land Yacht/Legacy Motorhomes 6 09-28-2011 05:55 PM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Seals For Wheel Bearings ~ 1958 Pacer Ariz-Pacer Wheels, Hubs & Bearings 9 03-22-2011 10:50 PM
