Old 11-24-2009, 04:05 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Wheel Bearings for 60's Airstream
First Airstream for me.A 1965 Ambassador.Where do I shop for wheel bearing seals and brake parts?
bwaysteve is offline   Reply With Quote
Old 11-24-2009, 04:45 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You could get them at any good auto supply shop. If none in your area try
etrailer.com - Bearings Races and Seals
2004 Excursion 4x4
Old 11-24-2009, 04:48 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
For your brakes get get full assemblies like this. Trailer Parts Superstore - Electric Trailer Brake Assemblies. This is an example. You probably have 10" brakes. Take a look though to make sure. The new bell and whistle is self adjusting trailer brakes. Take the wheel bearings and seals to NAPA and get a replacement. Inspect the bearings first odds are they are still good and just need repacked. Defiantly get a new seal.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-24-2009, 04:52 PM   #4
The original grease seals used felt. They are no longer available.
A special after market seal was created a few years ago.
You local parts store may not have them.
Your original brakes were 12 inch electric.
The shocks are a standard NAPA part.
Old 11-24-2009, 05:57 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can get brake parts from Redneck Trailer, etrailer.com, or almost any trailer supply and repair shop. Napa was able to supply me with grease seals for our '63 Overlander, and may still be able to get them.
Old 11-24-2009, 07:18 PM   #6
JimGolden's Avatar
1977 31' Excella 500
I was gonna say "Just call Inland Andy", but if you want to do it locally, you could pull the old ones, take them to the local NAPA and have him get you some.
My buddy runs the local NAPA, and I just pulled one set of everything off mine (I still have five left to hold it off the ground ) and had him order me six of everything.
That was two years ago, so I should probably repack them this summer. I'm guilty of not doing it every year, but about every third.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Regreasing wheel bearings on a new Airstream nangoff Wheels, Hubs & Bearings 86 06-14-2010 06:24 AM
Tornadoes, Wheel Bearings, New Airstream! wishsilver Member Introductions 18 05-16-2008 03:59 PM
Airstream Wheel Bearings Hunter_1 Member Introductions 15 04-18-2006 02:54 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
