Old 08-15-2016, 08:05 AM   #1
1965 mustang's Avatar
Stoughton , Wisconsin
Wheel bearing tightness
Repacked my bearings, spun the hub while tightening the castle nut. Then backed off a 1/4 turn. Took the AS for a ride up to camping world and back, about 35 miles. Jacked her up and there is a little play when I push-pull on the tire. Is this normal? Would this be end play tolerance? Or are they to loose? All four wheels have about the same amount of play.
1965 mustang is offline   Reply With Quote
Old 08-15-2016, 08:13 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is common. If you tightened the bears snug with channel locks while turning the wheel and then backed off you should then be able to just feel movement while rocking the tire top and bottom.
Lack of this feeling is not good as the bearing is too tight and will heat up.
2004 Excursion 4x4
Old 08-15-2016, 08:52 AM   #3
Missouri Valley , Iowa
I am with HowieE. It sounds, from your description, like you have them about right. Especially if all 4 are the same.
Dan
Farmer Dan is offline   Reply With Quote
Old 08-15-2016, 09:33 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Take a look here.
http://www.airforums.com/forums/f465/tapered-bearing-adjustment-procedure-videos-143119.html
Has a video by Timken in it.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-15-2016, 10:24 AM   #5
2005 30' Classic
Burlington , Ontario
A little play should be fine if you previously snugged them up well - but "little" should be the key word!
I think the play should be barely noticeable, i.e. a few thou.
Brian.
Old 08-15-2016, 11:52 AM   #6
2015 25' FB Flying Cloud
Sandy , Utah
Everyone is correct here. One important step is to make sure that you tighten them enough to seat the bearings first before backing off to get a little "wobble".
rocco52 is offline   Reply With Quote
Old 08-15-2016, 06:23 PM   #7
Does everyone back off a 1/4 turn?
Old 08-15-2016, 07:07 PM   #8
2005 30' Classic
I back off only to the next slot in the castle nut where I can get the cotter pin through!
Brian.
Old 08-15-2016, 07:15 PM   #9
Thanks Brian. They just seem a little to sloppy.
Bearing Buddy Bearing Protectors Ron A Wheels, Hubs & Bearings 23 05-19-2015 07:48 AM
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 06:50 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 08:36 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 09:54 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 04:35 PM
