Old 08-13-2019, 11:55 PM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
Wheel bearing seals
I am about to try and repack the wheel bearings on my airstream. This is the first time that I have ever tried to repack bearings ut I understand that I should replace the seals as I repack the bearings. Can someone tell me how I can make sure I get the right replacement seals? are there model or serial numbers on the old seals that would give me some idea? Thanks.
tracker is offline   Reply With Quote
Old 08-14-2019, 04:30 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You just need seals for 12" trailer hubs, they are not really special for Airstream trailers. The good seals are double lip seals, but standard ones will work.
Old 08-14-2019, 05:09 AM   #3
Kevin245's Avatar
Ditto what Terry indicates. The seals are not proprietary to Airstream. They do have part numbers etched on the face, however they may not be legible. I keep a spare set of bearing and seals in my RV toolbox, but they are not close at hand at this writing.
See if this helps. https://www.etrailer.com/Trailer-Bea...GS-2250DL.html
If you have questions give the folks at etrailer a call and they should be able to provide assistance over the phone. I've dealt with them for years and had great service. YMMV.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 08-14-2019, 06:35 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Napa auto parts has the best selection. Bring your old ones with you.
X2 on the double lip
Old 08-14-2019, 10:50 PM   #5
SandKSmith's Avatar
Scottsdale , Arizona
I called Dexter, gave them my 2006 Safari VIN and they emailed me the build sheet for my axles. Seal part numbers were on it, and she also gave me the part number of the lift kit we wanted. They were really helpful.
Steve
SandKSmith is offline   Reply With Quote
Wheel bearing seals Craig Schrader Wheels, Hubs & Bearings 1 11-27-2013 09:04 AM
Wheel! bearing seals - 1966 Mike_cfi 1965 - 1969 Globetrotter 5 07-07-2013 07:11 PM
Wheel bearing seals steveirving Wheels, Hubs & Bearings 4 07-03-2013 05:14 AM
16' CCD Wheel Bearing & Seals Part Numbers RDM16CCD 2005 and newer - Bambi all models 0 05-21-2009 04:37 PM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
