Old 07-02-2013, 08:47 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Wheel bearing seals
Hi all,
the seals on our wheel bears seal (on our '59 Tradewind) are leaking a little grease into the brake drum.
Part number looks to be 291148 made in the USA.
Looking for help in locating two of these seals to replace the leaky ones.
Steve
2282094561
steveirving is offline   Reply With Quote
Old 07-02-2013, 09:24 AM   #2
Originally Posted by steveirving View Post
Hi all,
Steve
2282094561
We have records that go way back, but I could not find a listing for that seal number.
Please provide some accurate dimensions and I will continue the search.
Old 07-02-2013, 05:09 PM   #3
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Steve,
Take it out and bring it to your local auto suppy. They can reference the number or cross reference it to get the appropriate seal for you.
Most times they have them in stock or can get them overnight.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 07-02-2013, 06:25 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Assuming it is a 3 inch diameter seal as both my 54 and 61 were here are a couple numbers to try that I found on my trailers.
National 203034
Chicago Rawhide 18808
The best fit I found was a seal from Trailer hitch, hitches and bike rack (800)298-8924 which I got to by referencing other numbers. It is 3.005 diameter. I don't have their part number here but the E trailer number does cross ref. back to kelsey hayes We are travelling right now and I don't have all my notes. At least one of the other numbers is 2.998 diameter and might work loose if no adhesive is put on it.
A google search for your part number should bring up numerous cross reference guides as well as some airforums threads
I also found that E trailer was the only source for drive in dust caps to fit my 61 which are 2.25 diameter
UPDATE: This is the etrailer seal
http://www.etrailer.com/Seals-for-Tr...ine/29031.html
If your seal is not 3 inch diameter just ignore most of what I wrote
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-03-2013, 05:14 AM   #5
1959 24' Tradewind
Quantico , Virginia
Images: 11
Thanks for the detailed answer. We are also on the road. Ill measure them on e we stop for a few days
