Old 12-16-2016, 03:35 PM   #1
Randakk's Avatar
2015 23' FB Flying Cloud
Pinehurst , North Carolina
Wheel Bearing Dust Seals?
Getting prepared to do wheel bearing service for the first time on our 2015 23FB.
Can anyone verify the size / part number for the dust seals I will need?
Thanks in advance.
Randall Washington (Randakk)
Pinehurst, NC
2015 Flying Cloud 23FB
2015 Chevrolet Silverado 1500 WT 4WD
www.randakks.com
Randakk is offline   Reply With Quote
Old 12-19-2016, 07:28 AM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
The numbers you need are listed on the Dexter axle website.
Old 12-19-2016, 08:23 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thanks in advance.
Two options:
1. My first choice - The guys at ODM can tell you everything you need to know about your trailer, they have the parts in stock, and they will ship the parts to you quickly. The last seals I bought there were very reasonably priced, less expensive than the local auto parts store.
2. After removing the wheel and brake hub you will see there is a number printed on the metal portion of the seal. An automotive store can cross reference those numbers and give you whatever they have in stock. All seals are not the same quality, so be careful. (make sure it has a double seal)
both of my trailers use this
http://odmrv.com/catalog/index.php?m...oducts_id=1185
Alan
Old 12-19-2016, 10:34 AM   #4
Moflash's Avatar
I would avoid Chinese made wheel bearings and order Timken USA made from Amazon.
Most auto parts stores stock Chinese made bearings only
Old 12-20-2016, 01:08 PM   #5
2014 30' Flying Cloud
Milton , Ontario
If this is a new Airstream it has sealed bearings which do not need servicing. The brakes are also self adjusting. Read the axle information in your owner brochure kit and it will explain what you have
Norrie46 is offline   Reply With Quote
Old 12-20-2016, 03:57 PM   #6
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Also the Dexter book that came with 5he trailer.
MelGoddard is offline   Reply With Quote
Old 12-20-2016, 04:34 PM   #7
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
And if your Dexter owners manual is like mine, Airstream put the tags with the serial number on them in the manual. You can call Dexter's customer service and they can tell you what kind of bearings and seals you need from those numbers. If you take the wheel off and see something that says neverlube you have the cartridge style bearing, which is a sealed ball bearing. Hope this helps. Mike
Mike S. is offline   Reply With Quote
Old 12-21-2016, 10:35 AM   #8
Randakk's Avatar
Thanks for the replies above.
My trailer and all the manuals are in storage at the moment and I live in a neighborhood with restrictive covenants. I am severely limited as to how much time I can have my trailer on my driveway for maintenance. That's why I needed to round up all these parts before I begin to take the wheels apart.
I just verified what I need with Justin at Dexter Parts Online (very helpful!) http://www.dexterpartsonline.com
The Airstream part number, for the grease seal on my trailer is #680370-100. This cross-references to a Dexter 10-36 seal which is the so-called "blue seal" which has a blue ring around the edge, a double flare, a spring in it and has metal on both sides.
Apparently, our 2015 23FB is a bit of an "odd duck" axle wise. It has 3000# rated axles with a mixture of light and heavy duty axle parts, 10" drums with 5 lug hubs. Unlike many modern Airstreams, my axles have the old-fashioned bearings that require periodic service.
Thanks again.
Pinehurst, NC
www.randakks.com
Dust Dust Dust Lumatic General Interior Topics 9 05-16-2016 08:35 AM
Wheel! bearing seals - 1966 Mike_cfi 1965 - 1969 Globetrotter 5 07-07-2013 07:11 PM
16' CCD Wheel Bearing & Seals Part Numbers RDM16CCD 2005 and newer - Bambi all models 0 05-21-2009 04:37 PM
How to remove wheel bearing dust covers ldetsf Axles 12 11-08-2006 01:39 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
